Doug_R1 Posted September 21, 2010 Report Share Posted September 21, 2010 I must get around to balancing the throttle bodies on my bike, but with fuel injection is a gravity feed ok, or does it need connecting to the fuel pump for the correct pressure? I was wondering if anyone knew if an extension pipe was available, so you can hook the tank up off the bike. Link to comment Share on other sites More sharing options...
lorenzo Posted September 21, 2010 Report Share Posted September 21, 2010 Definately needs the fuel pump. You could buy a length of fuel hose from 99% of motor spares shops, just get generic braided stuff (to cope with the pressure) of the right diameter. Your problem however will come when you find it's got funky fittings at one end or perhaps both. If you're lucky enough to find it's just held on with a jubilee clip then it's a doddle, otherwise you've got to see if you can do something with the attachments, which'll be tricky. Link to comment Share on other sites More sharing options...
ronenige Posted September 22, 2010 Report Share Posted September 22, 2010 Easiest way is to take the tank off , connect up your gauges and have a look where the air bleed screws are , reconnect your tank at the back supported at the front with a lump of wood or similar , get the bike warm and balance away , what model R1 is it ? Link to comment Share on other sites More sharing options...
Doug_R1 Posted September 22, 2010 Author Report Share Posted September 22, 2010 It's not the R1, the 4XV had carbs, hence the gravity feed languishing in the shed. It's a 2005 Kawasaki ZX6R C1H, with the clip fittings, I don't see how I could turn the tank and connect it. Link to comment Share on other sites More sharing options...
ronenige Posted September 22, 2010 Report Share Posted September 22, 2010 Kawasaki do an extension tube , according to the manual the part no is 57001-1578 . cost is £23.86 hth Link to comment Share on other sites More sharing options...
Doug_R1 Posted September 22, 2010 Author Report Share Posted September 22, 2010 Thanks for that, I thought there must be an easy way to do it. Link to comment Share on other sites More sharing options...
