Powerwheelie Posted September 11, 2010 Report Share Posted September 11, 2010 Would a rs 125 be good for a 200 mile trip in one day or not ? Link to comment Share on other sites More sharing options...
SHimmer45 Posted September 11, 2010 Report Share Posted September 11, 2010 yeah be fine... keep varying the revs and id be inclined to turn the oil pump up slightly. oil plug better than nipping up Link to comment Share on other sites More sharing options...
Powerwheelie Posted September 11, 2010 Author Report Share Posted September 11, 2010 yeah be fine... keep varying the revs and id be inclined to turn the oil pump up slightly. oil plug better than nipping up I was going to stick a bigger jet in and add abit oil to the petty. Easier than turning up the oil pump> So yeah it should be okay to do 200 mile with a few stops. It's in spot on conditon last time i checked it had 160psi. Link to comment Share on other sites More sharing options...
rgvneil Posted September 12, 2010 Report Share Posted September 12, 2010 My bro rode 155 miles to Le Mans in just over 3 hours cruising happily at 85mph. Good little bikes those. Link to comment Share on other sites More sharing options...
Powerwheelie Posted September 12, 2010 Author Report Share Posted September 12, 2010 My bro rode 155 miles to Le Mans in just over 3 hours cruising happily at 85mph. Good little bikes those. Good stuff, I've got a Lammy GP 225 with a TS1 engine engine to keep up with. If anyone knows about lammy's they'll know my 125 is gonna have to work hard lol. Link to comment Share on other sites More sharing options...
wazrs257 Posted September 14, 2010 Report Share Posted September 14, 2010 If you add pre-mix you'll need to up-jet to compensate, as a slightly smaller proportion of the fuel will be petrol & hence a leaner mixture. Apart fom that, go for it. Link to comment Share on other sites More sharing options...
Powerwheelie Posted September 15, 2010 Author Report Share Posted September 15, 2010 If you add pre-mix you'll need to up-jet to compensate, as a slightly smaller proportion of the fuel will be petrol & hence a leaner mixture. Apart fom that, go for it. Yeah mate i will be up-jetting. From a 162 to a 170 probably. Link to comment Share on other sites More sharing options...
Acid Posted September 15, 2010 Report Share Posted September 15, 2010 Rs125 took me and the gf two up with camping gear on a round trip of donagal 500 miles in 2 days 400 day one and 100 back home. revs never dropped below 10k ( trying to keep up with ktm Sd's gsxr 1000,s ect) make sure to check your chain Link to comment Share on other sites More sharing options...
Powerwheelie Posted September 17, 2010 Author Report Share Posted September 17, 2010 Rs125 took me and the gf two up with camping gear on a round trip of donagal 500 miles in 2 days 400 day one and 100 back home. revs never dropped below 10k ( trying to keep up with ktm Sd's gsxr 1000,s ect) make sure to check your chain Cheers for that mate and yeah i know but i've got a good 4-5 month before the trip. I made this post to see if i should buy myself a 4t 125 for the trip. Link to comment Share on other sites More sharing options...
Acid Posted September 18, 2010 Report Share Posted September 18, 2010 Cheers for that mate and yeah i know but i've got a good 4-5 month before the trip. I made this post to see if i should buy myself a 4t 125 for the trip. I done this trip on an xr125 last year and 55 flat out drivin part was so boring. The rs was only getting 14 ish mpg tho and done nearly a full litre of modul 710 oil. Link to comment Share on other sites More sharing options...
