Kawasakifreak Posted August 14, 2010 Report Share Posted August 14, 2010 I'm looking to improve carburation on my streetfighter Kawasaki ZX7R P1. Any opinions about Keihin FCR carbs & which size would be best ? I'm looking to inprove bottom & mid-range response - engine standard cams & ignition timing at the moment. Thanks. Link to comment Share on other sites More sharing options...
speedy sie Posted August 14, 2010 Report Share Posted August 14, 2010 for get this idea for a road bike as the crf's are for the track and will only make the bike worse,go over to redmonkey and there is a thred about this mod. better of getting yours dyno'ed and set up right. Link to comment Share on other sites More sharing options...
spacemonkey Posted August 14, 2010 Report Share Posted August 14, 2010 for get this idea for a road bike as the crf's are for the track and will only make the bike worse,go over to redmonkey and there is a thred about this mod. better of getting yours dyno'ed and set up right. Absolute, unjustified cobblers... They are brill, plus much more adjustable than standard carbs. just make sure you don't use a set that is too big (35 or 37mm perhaps.) and get them properly set up on a dyno. Link to comment Share on other sites More sharing options...
speedy sie Posted August 14, 2010 Report Share Posted August 14, 2010 http://www.redmonkey.com/7r/messages.php?msg=23391.1 http://www.redmonkey.com/7r/messages.php?msg=23107.1 as it states,set up right they are great,but unless you are a master of the throttle,the things will bog the bike down,not the best mod for a rider who just wants a bit more ummppff, and the fitting of the crf's in to zx7r air box is a bit more than you think,it is not a simple bolt out and bolt in.... iv had a zx7rr with the 41mm acselerater pump carbs and yes bloody great,but you have to understand about throtle aplication,as the rider has a greater imput to the air fule mix,and unless you understand wot the carbs are actualy doing then you can over flood the engine with a good fist full of throttle,and to little throttel can weken the mix ,so all in all a good mod for a proper experenced rider,but not one for the week end rider. id say yes to the mod as i love flat slides,but get the bike a full akey,k&n and dyno and this is a better simpler tune up. Link to comment Share on other sites More sharing options...
Evilchicken0 Posted August 14, 2010 Report Share Posted August 14, 2010 I wouldn'y look to fit flatslides for low down repsonse ... they're more track orientated, and although it depends on how they're set up you should find CV's better for road use. If you want to make the bike more ridable low down consider a smaller carb diameter or lower the gearing Link to comment Share on other sites More sharing options...
spacemonkey Posted August 14, 2010 Report Share Posted August 14, 2010 http://www.redmonkey.com/7r/messages.php?msg=23391.1 So you'll have to enlighten me on what a logon screen proves..... Link to comment Share on other sites More sharing options...
Barry Posted August 14, 2010 Report Share Posted August 14, 2010 just make sure you don't use a set that is too big (35 or 37mm perhaps.) and get them properly set up on a dyno. ZX7 N uses 41mm as standard. The ZXR750 K & M models use 39. 39's are better than the 41's for bottom end and mid range, pointless going smaller. I have 39mm FCR's on my ZXR750M, and I'm also running a set of 39's on my 7R(N) track bike with ZX9 engine. Both carbs are now running all jets as per the race kit manual and pull like a train from around 2k rpm. Cost me around £300 to jet both sets of carbs to race kit spec. Link to comment Share on other sites More sharing options...
spacemonkey Posted August 14, 2010 Report Share Posted August 14, 2010 ZX7 N uses 41mm as standard. The ZXR750 K & M models use 39. 39's are better than the 41's for bottom end and mid range, pointless going smaller. I have 39mm FCR's on my ZXR750M, and I'm also running a set of 39's on my 7R(N) track bike with ZX9 engine. Both carbs are now running all jets as per the race kit manual and pull like a train from around 2k rpm. Cost me around £300 to jet both sets of carbs to race kit spec. I don't suppose you have dyno runs to compare with CV carbs? Would you swap back to CV's or are you happier with the FCR's? Link to comment Share on other sites More sharing options...
speedy sie Posted August 14, 2010 Report Share Posted August 14, 2010 So you'll have to enlighten me on what a logon screen proves..... sorry just press the guest button and it will then put this the up. Link to comment Share on other sites More sharing options...
spacemonkey Posted August 14, 2010 Report Share Posted August 14, 2010 sorry just press the gues button and it will then put this the up. Sorry, I should've seen that guest button! Still, that's one guy's opinion, he doesn't give reasons for his opinion, he possibly hasn't even tried them..... He could be talking rubbish. It'll be interesting to hear more from guys that use them like Barry. I've got fantastic bottom end pull from FCR carbs before. There is absolutely no reason they should be rubbish for the road. In fact they should be better because you have more possible adjustments. The only thing I can think of that makes them less suitable that CV's is that they often don't have a choke. - But a couple of twists of the throttle and the pumps will give you a rich enough mixture for cold starting.... I've found most people who go around saying they are unsuitable for road bikes have either not tried them or they've tried carbs that are too big. Sorry to come on a bit strong but loads of people just repeat stuff they've heard 82nd hand, and it becomes gospel when enough people say it. - Doesn't make it true though. It's like chinese whispers! Link to comment Share on other sites More sharing options...
speedy sie Posted August 14, 2010 Report Share Posted August 14, 2010 no problemo..once you have masterd the two pump to start,and get use to fethering the throttle i loved them,and would fit them over fi,but alas the fi does the stuff at 4 am every moring,but the flat slides do put the soul in to a bike,and as you have said,well set up they are brill.but to just add them to a bike and expect super power is a bit unreal. riding a biike with well set up flat slides,and getting the throtle masterd is one of the best feelings in bikeing,in my view,but then a againe im gods own dispach ridder.... Link to comment Share on other sites More sharing options...
spacemonkey Posted August 14, 2010 Report Share Posted August 14, 2010 no problemo..once you have masterd the two pump to start,and get use to fethering the throttle i loved them,and would fit them over fi,but alas the fi does the stuff at 4 am every moring,but the flat slides do put the soul in to a bike,and as you have said,well set up they are brill.but to just add them to a bike and expect super power is a bit unreal. riding a biike with well set up flat slides,and getting the throtle masterd is one of the best feelings in bikeing,in my view,but then a againe im gods own dispach ridder.... Is there a 4 in the morning? :-o My sympathy! I suppose nothing is any good if it is not set up right... EFI, CV carbs, flatslides, etc can all be made to work badly! Not many things give such an easy power gain though! ... And they probably cost less than an Akrapovic or somesuch.... Link to comment Share on other sites More sharing options...
Barry Posted August 14, 2010 Report Share Posted August 14, 2010 I don't suppose you have dyno runs to compare with CV carbs? Would you swap back to CV's or are you happier with the FCR's? No sorry, never had CV's on these bikes, infact I've not ridden a bike running CV's for ages now thinking about it!! As long as you don't crack the throttle wide open at low rpm then you'll be fine with FCR's. It's all about progressive throttle control rather than just wack it open and let the slides take care of it with CV's. I sold a spare set of 39's a couple of weeks ago for £300, which is what they usually go for, sometimes a bit more but very rarely for less. Unless the person selling doesn't know what they have! Both my bikes are running the 39's (as mentioned) and both in carbon race airboxes. The jetting is way different than the normal road setup they they come with as stock, and low throttle responce on mine is amazing. As its been mentioned above, you need to get it setup really and the slightest changes to any of the jets can make a big difference. Link to comment Share on other sites More sharing options...
heds954 Posted August 14, 2010 Report Share Posted August 14, 2010 As long as you don't crack the throttle wide open at low rpm then you'll be fine with FCR's. It's all about progressive throttle control rather than just wack it open and let the slides take care of it with CV's. I've been told the very same by my local dyno man. When properly set up they do as Barry put it 'pull like a train' apparently, whereas a CV set will tail off FCRs will just keep going and going and going. Which is why I might be after a set of 33 or 35's for my steelie Link to comment Share on other sites More sharing options...
suspensionsmith Posted August 15, 2010 Report Share Posted August 15, 2010 One thing to be aware of on high milage FCR is how they have that trademark slide rattle at idle,the little rollers on the slides will over time wear grooves in the carb body that they roll upon,making off idle/part throttle control impossable...I have repaired a few with this problem. Other than that these carbs absolutely rock when setup well. Link to comment Share on other sites More sharing options...
spacemonkey Posted August 15, 2010 Report Share Posted August 15, 2010 One thing to be aware of on high milage FCR is how they have that trademark slide rattle at idle,the little rollers on the slides will over time wear grooves in the carb body that they roll upon,making off idle/part throttle control impossable...I have repaired a few with this problem. Other than that these carbs absolutely rock when setup well. Ah yeah... Then they start busting slides.... But to be fair thins happens with a lot of CV carbs too. The slide guides wear and then the slides start to stick at low positions.... Link to comment Share on other sites More sharing options...
eddie Posted August 19, 2010 Report Share Posted August 19, 2010 I have to agree with Barry. I have a zxr 750 K1, that has the FCR 39's on it, and it does pull like a train. It feels like it has so much more power than other bikes Ive had/ridden. Before I bought it, i read loads about the "bogging" down whilst pulling away etc,and how bad these carbs were on the road, but to be honest, I've never noticed it pulling away or at any other time. I only use the bike on the road. . However there can be drawbacks the small bit was rattling around on top of the valves! Bike was still running, and after a 3 month wait for a new part, it still does! Paul Link to comment Share on other sites More sharing options...
fran9r Posted August 19, 2010 Report Share Posted August 19, 2010 Wow. Eddie, do your FCRs have a groove where the slide wheels have worn the carb body? Link to comment Share on other sites More sharing options...
Kayla Posted August 20, 2010 Report Share Posted August 20, 2010 FCRs are awesome. I've got a pair of 41s on my TRX and they are so much better than the standard CVs. There is more of everything, everywhere. My bike gets ridden on the road and it must be an urban myth that they're crap on road bikes. Link to comment Share on other sites More sharing options...
peter187 Posted August 22, 2010 Report Share Posted August 22, 2010 There's nothing wrong with flatslides on a streetbike. If you are bogging them down you are just completely cackhanded with the throttle. My YZF runs them and I've had absolutely no problems riding on the road with them. Link to comment Share on other sites More sharing options...
hamill12 Posted August 26, 2010 Report Share Posted August 26, 2010 I have a set of Keihin 39mm FCR on a GSXR K2 1000. Ive got to say its a lot of fun. Does what it says on the packet Race performance. Pulls well im happy with them. Link to comment Share on other sites More sharing options...
