speedy sie Posted August 5, 2010 Report Share Posted August 5, 2010 fist fo all send the miss's out for the morning,put on some tunes you like,may be a bear,calm your self down,as working on your srad sould be a zen moment of pure harmoney,man and mechine,all sitting to squire comfertabaley on your bottey ,then ill begine 1,remove the tank as this is a lot easer. 2,open the air box up,and remove the fillter. 3,now read carfully as you can fuck up big time.... a,with a dremal,or better an air hack saw,cut the air vale out,the object is to cut round the inside of the air fillter seal resess,start at the front and work round to the back,once cut out then pull the air flap off,you can do this first as it makes it easer,leave the air flat actuater in place,does no harm. b,this is the most important part,the seal when cut out does not go all the way to the back,put your hand under the were the air flap is and you will feel that the air fillter seal is actualy about 5mm in fromt the under side of the air box back,dont cut all the way back to the rear of the seal,as you will cut the rear lower part of the air box c,once you have removed this part,then clean up the edge as close to the air box seal lip,and the job is done,the air fillter can now be put back in and it wiil still seal on wot is left of the seal lip in the air box. d,on injrction srad's you will have to have the fueling reset up,no need for a pc..just tack it to your local suzuki dealer and they can remap the fueling,as for the carbed model a dyno visit is needed. once done the bike will rev up quicker,and doed add a bit more top end,a respoket is the best deal to get the graring right. my next mod is a full middle section removel,you can see wot i mean when you have done this mod,i will remove the compleat middle section,and run no air fillter,as in the kit/factory set up. this mod is the beat 1/2hr you can spend with your beloved srad. mod can also be done on the tl.. this mod still uses the standered ram tube set up,but for the next inductuion mod,you will need a set of full lenght ram tubes,mentalslider do a set of the yoshey kit ram tubes that go in to the air box(i think they do you will have to ask daz),thses go through the frame and into the air box,no rubber needed,as in the factory set up. once all this done the bike will be a difrent bike,and the air box does growel. Link to comment Share on other sites More sharing options...
originalracingsnake Posted August 5, 2010 Report Share Posted August 5, 2010 It is like reading the instructions from a Chinese made gadget. Also, the TL does NOT respond to having its airbox fucekd about with. You need a Sam Mathewman box, or a Terry Shep one. Dicking with the std one does fuck all except make more noise. Which is nice, but if you are after a performance gain on the TL, forget it. Link to comment Share on other sites More sharing options...
sennidott Posted August 5, 2010 Report Share Posted August 5, 2010 It is like reading the instructions from a Chinese made gadget. Also, the TL does NOT respond to having its airbox fucekd about with. You need a Sam Mathewman box, or a Terry Shep one. Dicking with the std one does fuck all except make more noise. Which is nice, but if you are after a performance gain on the TL, forget it. Pot, kettle, black... Get a grip ffs! Link to comment Share on other sites More sharing options...
Conica Posted August 5, 2010 Report Share Posted August 5, 2010 Give Sie a break, Dyslexia isn't something you choose to have Link to comment Share on other sites More sharing options...
krazyk Posted August 6, 2010 Report Share Posted August 6, 2010 I've got both mods on mine, it makes a big difference above 6k. Yoshi mapped ECU takes care of the changes. Two small things from Sie's warning when cutting out, Injection box if you look towards the back of the air filter seal you can see 4 rings running across the base, dont cut more than halfway back, best is to cut to the front of the rings and then Dremmel the rest out, this also gives you a bit of room to clean up the cut and Bevel the edges. Don't forget the airbox frame seals. Link to comment Share on other sites More sharing options...
ringdingtim Posted August 6, 2010 Report Share Posted August 6, 2010 fist fo all send the miss's out for the morning,put on some tunes you like,may be a bear,calm your self down,as working on your srad sould be a zen moment of pure harmoney,man and mechine,all sitting to squire comfertabaley on your bottey ,then ill begine 1,remove the tank as this is a lot easer. 2,open the air box up,and remove the fillter. 3,now read carfully as you can fuck up big time.... a,with a dremal,or better an air hack saw,cut the air vale out,the object is to cut round the inside of the air fillter seal resess,start at the front and work round to the back,once cut out then pull the air flap off,you can do this first as it makes it easer,leave the air flat actuater in place,does no harm. b,this is the most important part,the seal when cut out does not go all the way to the back,put your hand under the were the air flap is and you will feel that the air fillter seal is actualy about 5mm in fromt the under side of the air box back,dont cut all the way back to the rear of the seal,as you will cut the rear lower part of the air box c,once you have removed this part,then clean up the edge as close to the air box seal lip,and the job is done,the air fillter can now be put back in and it wiil still seal on wot is left of the seal lip in the air box. d,on injrction srad's you will have to have the fueling reset up,no need for a pc..just tack it to your local suzuki dealer and they can remap the fueling,as for the carbed model a dyno visit is needed. once done the bike will rev up quicker,and doed add a bit more top end,a respoket is the best deal to get the graring right. my next mod is a full middle section removel,you can see wot i mean when you have done this mod,i will remove the compleat middle section,and run no air fillter,as in the kit/factory set up. this mod is the beat 1/2hr you can spend with your beloved srad. mod can also be done on the tl.. this mod still uses the standered ram tube set up,but for the next inductuion mod,you will need a set of full lenght ram tubes,mentalslider do a set of the yoshey kit ram tubes that go in to the air box(i think they do you will have to ask daz),thses go through the frame and into the air box,no rubber needed,as in the factory set up. once all this done the bike will be a difrent bike,and the air box does growel. Thanks for this fella,only had my srad track bike for about 4 weeks and was wondering what could be done to it to liven it up."Dremmel ahoy" Link to comment Share on other sites More sharing options...
lorenzo Posted August 9, 2010 Report Share Posted August 9, 2010 ringdingtim, if you do this mod, could you take photos and post them up here, so I don't fuck it up completely when I do mine! Link to comment Share on other sites More sharing options...
krazyk Posted August 9, 2010 Report Share Posted August 9, 2010 ringdingtim, if you do this mod, could you take photos and post them up here, so I don't fuck it up completely when I do mine! Lawrence is yours carb or Fi if FI I can do some of mine Link to comment Share on other sites More sharing options...
MarkB Posted August 9, 2010 Report Share Posted August 9, 2010 Lawrence is yours carb or Fi if FI I can do some of mine Krazyk - mines FI so any pics would be good cheers Link to comment Share on other sites More sharing options...
V6Jon Posted August 9, 2010 Report Share Posted August 9, 2010 And mine is carb if anyone can supply piccies. Ta Link to comment Share on other sites More sharing options...
lorenzo Posted August 9, 2010 Report Share Posted August 9, 2010 Lawrence is yours carb or Fi if FI I can do some of mine Mine's on carbs, it's a pretty early one. Link to comment Share on other sites More sharing options...
southwestbiker Posted August 14, 2010 Report Share Posted August 14, 2010 Would like to see some pics of the carb one as well please. Link to comment Share on other sites More sharing options...
ringdingtim Posted August 14, 2010 Report Share Posted August 14, 2010 Lawrence is yours carb or Fi if FI I can do some of mine I would be gratefull of some pics aswell,cheers. Link to comment Share on other sites More sharing options...
krazyk Posted August 22, 2010 Report Share Posted August 22, 2010 Sorry for the delay Guys I was going to just take foto´s of the finished one, but decided to mod the new one, remember this one is a fool inj box, according to Haynes the Fi can be used on the carb box but not vise-versa so here we go: differences the Fi has an IAT and IAP sensor and the IAC valve. the carb box just has a vent hose between the inlets. the IAC valve has to be removed on the FI airbox..... marked with washers ( for clarity ) three rings mentioned earlier in the thread DON`T go any further back than these rings IAC valve actuator , dont throw away you need this to reseal the box. IAC valve... remove seal needs replacing ( use draft excluder) its app. 10mm thick. view of cleaned inlet. valve retainers. cut out to rough line with pad saw or Dremel saw Link to comment Share on other sites More sharing options...
krazyk Posted August 22, 2010 Report Share Posted August 22, 2010 rough shaping done with this remove pins from IAC retainer so then all that needs doing is to smooth the sides and front to the filter retainer and rear to the underside of the inlet. HTH KK Link to comment Share on other sites More sharing options...
krazyk Posted August 25, 2010 Report Share Posted August 25, 2010 so last pics from me on this. The IAC actuator gets replaced to seal up the base, make new seals for frame joint and fit. The Yoshi programmed ECU takes care of the fuelling. HTH KK Link to comment Share on other sites More sharing options...
lorenzo Posted August 25, 2010 Report Share Posted August 25, 2010 If I was to do this on a carb'd bike, is there much in the way of fuelling changes that couldn't be sorted out via a trip to the dyno? That is, is it simply a case of bigger mains etc, as opposed to any serious modding of the carbs, and is it all reversable if need be? Link to comment Share on other sites More sharing options...
krazyk Posted August 28, 2010 Report Share Posted August 28, 2010 If I was to do this on a carb'd bike, is there much in the way of fuelling changes that couldn't be sorted out via a trip to the dyno? That is, is it simply a case of bigger mains etc, as opposed to any serious modding of the carbs, and is it all reversable if need be? should go on just jets and needles, still need a Dyno run though Link to comment Share on other sites More sharing options...
krazyk Posted August 28, 2010 Report Share Posted August 28, 2010 Is anyone interested in this one FI will sell after Ive tested it. KK Link to comment Share on other sites More sharing options...
lorenzo Posted August 28, 2010 Report Share Posted August 28, 2010 should go on just jets and needles, still need a Dyno run though Coolio, I'll do it when I fit my exhaust and the carbon tubes, get it all done at once. Thanks very much too, the photos make it much more clear. Link to comment Share on other sites More sharing options...
pullingmyplonker Posted August 29, 2010 Report Share Posted August 29, 2010 if you do this mod to the carb 750 model srads you have to block the main air jet and maybe change the main jet, i done this with a akropovic full system and ran cyl 1/4 127.5 cyl 2/3 130 main jet otherwise you have to run 170+ main jets and standard they run 1/4 - 125 2/3 - 127.5 there are pics of where the main air jet is on www.factorypro.com under gsxr 750 96-97 section Link to comment Share on other sites More sharing options...
lorenzo Posted August 29, 2010 Report Share Posted August 29, 2010 Thanks for the link, but I think you've just foud the candidate for the most impossible to read website ever. I'll have a word with my Dyno guy on tuesday, see what he's saying. Link to comment Share on other sites More sharing options...
