stubbsy Posted July 21, 2010 Report Share Posted July 21, 2010 Hey all, Got to the stage on my Gilera Nordwest project where I want to improve the look of the engine a bit. It should have a nice silver finish, but this is all flaking/corroded. I've got the motor all stripped down at the moment, so what is the best way to go to get the corrosion/flaky paint removed. (best left to a professional or possible at home?) Then planning to paint the engine black, what prepping/priming etc should be done first? Are the over the counter engine paints any good/ what do you recommend? Questions, questions!!!! ........ cheers in advance for the help Link to comment Share on other sites More sharing options...
blow_away Posted July 22, 2010 Report Share Posted July 22, 2010 Jeff, this is the best paint for engines http://www.thefastone.co.uk/proddetail.asp?prod=PJ1 I can shotblast some bits for you if you can wait until the end of next week? Link to comment Share on other sites More sharing options...
stubbsy Posted July 23, 2010 Author Report Share Posted July 23, 2010 Jeff, this is the best paint for engines http://www.thefastone.co.uk/proddetail.asp?prod=PJ1 I can shotblast some bits for you if you can wait until the end of next week? Thanks for that Al, Brilliant..... I will definately take you up on your offer of the shot blasting if poss thanks. Will give you a call over the weekend Link to comment Share on other sites More sharing options...
