Annaz Posted July 17, 2010 Report Share Posted July 17, 2010 The new proud owner of my Srad trackbike left it in his garage over winter, got it out and bolted on 2k worth of goodies, took it to Mallory Park and when running it wouldn't engage gear. When it's turned off the gears are all there to be had So we think the clutch is stuck either on or off, I'm not sure coz I wasn't there. So apart from setting off up the road and revving the bingo wings off it how do we get it free? Link to comment Share on other sites More sharing options...
speedy sie Posted July 17, 2010 Report Share Posted July 17, 2010 piss easy to tack out the cluch and check the plates soak them over night and re fit. Link to comment Share on other sites More sharing options...
lorenzo Posted July 17, 2010 Report Share Posted July 17, 2010 Surely you can check if a clutch is engaged or not without even having the engine running: Stick it in gear, squeeze the lever and push it. If it's kinda smooth feeling then your clutch is OK. If you're coming up against resistance every couple of feet (as each cylinder gets compression) then your clutch is stuck. This may not be a very sympathetic way for sorting it, but put your bike with the front wheel facing square on against a wall, engine running and in neutral. Rev it to about 5k rpm, pull the clutch lever in then stomp on the gear lever. Bingo, your clutch is sorted. If may not be good for the box or the clutch plates but once off it can't hurt too much, can it. I know it worked on my old bike that'd been sat for about 2 years, it was all fine after that. Link to comment Share on other sites More sharing options...
Annaz Posted July 17, 2010 Author Report Share Posted July 17, 2010 Cheers guys They're fetching it over tomorrow so I'll check it out then, plenty to go on Link to comment Share on other sites More sharing options...
