DinoB Posted July 15, 2010 Report Share Posted July 15, 2010 Hi All Anyone got a link or info about the Brake Piston removal pliers seen in this months PB ??? Many Thanks Link to comment Share on other sites More sharing options...
heds954 Posted July 15, 2010 Report Share Posted July 15, 2010 Cheapest I can find here, you can find cheaper elsewhere on the web in the UK until you add ludicrous shipping charges and VAT Link to comment Share on other sites More sharing options...
Jazoli Posted July 15, 2010 Report Share Posted July 15, 2010 I know that Draper do them, if you've split the calipers you can always use a cut down Rawlbolt Link to comment Share on other sites More sharing options...
V6Jon Posted July 15, 2010 Report Share Posted July 15, 2010 Sealey make them out of a special cheese that looks like metal, but has the strength of cheese. But you can't guess how I know Link to comment Share on other sites More sharing options...
Mr.Pigdog Posted July 15, 2010 Report Share Posted July 15, 2010 I have a set of them ones in the link--to be honest they're not all that for removing sticky pistons,just rotating good ones for a service/cleanup.Suppose it all depends on how seized we're talking but i found that that bracket with the 'clamp screw' opens out if put under any pressure-it's only supported on one side of the pliers if you see what i mean.I tend to use either the set with a slide hammer and various colletts or this little thing(only when caliper is split though) http://cgi.ebay.co.uk/Sealey-AK7112-Disc-B...=item1e5be6afd4 Link to comment Share on other sites More sharing options...
lorenzo Posted July 16, 2010 Report Share Posted July 16, 2010 Rawlbolt I'm liking that one. Link to comment Share on other sites More sharing options...
Doug_R1 Posted July 16, 2010 Report Share Posted July 16, 2010 I've got the Sealey ones, they are great for spinning the piston so you clean the hidden side. I pushed the piston back a little, to free the seal, and it spun easily. Link to comment Share on other sites More sharing options...
Lobo Posted July 16, 2010 Report Share Posted July 16, 2010 Always wondered if plastic pipe pliers would do the job - I know not to use the normal pipe pliers as they'll damage the piston - or will they just rotate the piston round ? something like these :- http://cgi.ebay.co.uk/Knipex-Plastic-Pipe-...#ht_2180wt_1139 We use similar pliers at work for doing up circular connectors in tight places, may borrow a set to see what they are like Link to comment Share on other sites More sharing options...
howiehowie93 Posted August 29, 2010 Report Share Posted August 29, 2010 Greetings, after reading the article in the Mag of a few months ago - I set about removing the pistons but they are not of the hollow type - but filled in with something or inserts or even in the wrong way !!!! How can you remove these - is there a tool ?? The body of the Calipers gets in the way for ordinary pliers.. regards & thanks in advance Howie Link to comment Share on other sites More sharing options...
Mr.Pigdog Posted August 29, 2010 Report Share Posted August 29, 2010 I usually do these kind by putting in a 1/4" socket extension bar where the disc normally runs and hydraulically pumping the pistons out as far as possible(so all of them come out),then removing the caliper and use a snap on airgun(has a rubber soft sealing face)to pneumatically blow the pistons out -chuck some rag over them as they can go ballistic!! Link to comment Share on other sites More sharing options...
lorenzo Posted August 29, 2010 Report Share Posted August 29, 2010 I've got an old slice of aluminum, about 5mm thick that I stick between the pistons, and then I just pump them out with the master cylinder, they'll come 95% of the way out and the final bit I can do by hand. Link to comment Share on other sites More sharing options...
vale Posted August 30, 2010 Report Share Posted August 30, 2010 I've got an old slice of aluminum, about 5mm thick that I stick between the pistons, and then I just pump them out with the master cylinder, they'll come 95% of the way out and the final bit I can do by hand. +1 on that one Link to comment Share on other sites More sharing options...
howiehowie93 Posted August 30, 2010 Report Share Posted August 30, 2010 Slight problem with that is the whole lot is in bits and master cylinder is still in (prolly) Harris' warehouse. Sorted it now by drilling and tapping a 6pm hole to pull out the pistons getting new anyway. H Link to comment Share on other sites More sharing options...
V6Jon Posted August 30, 2010 Report Share Posted August 30, 2010 I know that Draper do them, if you've split the calipers you can always use a cut down Rawlbolt Having been unable to get my Tokico six pot pistons out with my cheese pliers I thought I had nothing to lose by trying rawlbolts, and tis fucking genius I tell thee !! Bought a bolt for each piston size, and a spare nut for each bolt. Assembled this with the spare nut above the wall fixing. Then pushed the wall fixing into the psiton and tightened the spare nut down with a spanner. Eventualy the bolt grips sufficiently and you just twist the piston out. Worked first time on all but one of my twelve pistons, and that one came out after soaking in WD40 for an hour or so. Jon Link to comment Share on other sites More sharing options...
