bikemike Posted July 8, 2010 Report Share Posted July 8, 2010 Last time I took my Kr-1s out I noticed my rev counter was playing up. Thinking my rectifier was allowing the voltage to get too high I limped home and put a different rectifier on it. Took the bike out again- same problem. So I got the multimeter out and measured the voltage at the battery; this is what I got- At high idle (about 2000rpm) 13.7v- exactly what it should have. BUT- on increasing the revs the voltage started to drop steadily- by 8000rpm the voltage was down to 5 volts One point to bear in mind is that my battery is completely f***ed, it struggles to hold even a couple of volts. However it has been like this for a couple of years now and it hasn't caused me any problems (kick starts are wonderful things!). Any ideas folks? I think it is unlikely that both regulators have failed in the same way, could it be the stator? Help! Mike Link to comment Share on other sites More sharing options...
ronenige Posted July 8, 2010 Report Share Posted July 8, 2010 From what i remember generators are a common problem , these people can help http://www.westcountrywindings.co.uk/applications.htm but stick a new battery on as well Link to comment Share on other sites More sharing options...
cagimaha Posted July 8, 2010 Report Share Posted July 8, 2010 Go through this and see if it shows any faults. I've used it a couple of times and it's pretty comprehensive. Hope this helps, Ben. Link to comment Share on other sites More sharing options...
bikemike Posted July 8, 2010 Author Report Share Posted July 8, 2010 Go through this and see if it shows any faults. I've used it a couple of times and it's pretty comprehensive. Hope this helps, Ben. Cheers Ben, that looks very useful. I need to get a new battery first though! Mike Link to comment Share on other sites More sharing options...
a/s Posted July 9, 2010 Report Share Posted July 9, 2010 It'll be the generator - same thing happened on mine (back in '93 !) when it got high mileage,never had any of the usual problems with the rings/wonky barrels/KIPS valves tho cos the motor had been Blueprinted Link to comment Share on other sites More sharing options...
bikemike Posted July 9, 2010 Author Report Share Posted July 9, 2010 I never had any of the usual problems with the rings/wonky barrels/KIPS valves tho cos the motor had been Blueprinted Touch wood, mine has been trouble free since I put in a jewel of an engine built by Graham File. Remarkable what a difference it makes putting an engine together properly. Mike Link to comment Share on other sites More sharing options...
