tonk Posted July 6, 2010 Report Share Posted July 6, 2010 I've been quoted £70 to have 2 wheels powder coated satin black. I have to present the wheels without tyres, disc or bearings. Turnaround is 3 days. Does this sound reasonable? I intend to wait until I need to replace my tyres to save time and money. Other questions - is removing wheel bearings a pro job or within my capabilities as an enthusiastic amateur? Can they be re-used? Is satin paint durable or should I go gloss (the bike is used a lot, all year)? Thx Link to comment Share on other sites More sharing options...
stuntmonkee Posted July 6, 2010 Report Share Posted July 6, 2010 Sounds OK, I was quoted £50 per wheel locally Gloss Yes you'll be fine, big hammer required No you can't, buy new ones Link to comment Share on other sites More sharing options...
Devon Posted July 6, 2010 Report Share Posted July 6, 2010 changing bearings is definitely within your ability. just get a long rod or something and put it through the bearing and get it so that its resting on the oppostie bearing and hit with hammer, move the rod about so that the bearing is pushed out evenly, reducing any damage to the bearing seat. a place near me does wheels at 30 quid a wheel. i would reccomend putting old bolts in all holes like where the disc bolts will go s its very annoying trying to get the coating out and if possibly try and put something on the wheel so that when the disc is put back on you dont have to remove loads of paint off the wheel Link to comment Share on other sites More sharing options...
drunkn munky Posted July 6, 2010 Report Share Posted July 6, 2010 £50 a set in my neck of the woods Link to comment Share on other sites More sharing options...
will#224 Posted July 6, 2010 Report Share Posted July 6, 2010 Place near me is £40 a pair. The colour wont change the resistance to winter crud. Its your choice. Definately try and cover up all bearing, disk mount and threads, this would probably be done after the shot blasting, maybe your getting a deal where the person will do this for you. Link to comment Share on other sites More sharing options...
tonk Posted July 6, 2010 Author Report Share Posted July 6, 2010 I'll have to ask about the masking bit, might put the disc bolts in place, shot-blasting won't do them any harm. Ta for advice re bearings - I used to pop one out with an extension bar then use a socket on the same bar to drift the other one out. But that was on shitty bikes - this is still under warranty. The discs are a bit weird, they are bolted direct to the wheel on oval holes. No carrier. BMW bike but Brembo discs and wheels. Cheers guys. Link to comment Share on other sites More sharing options...
kaighn80 Posted July 6, 2010 Report Share Posted July 6, 2010 friend of mine has had some bits powder coated and on fitting them has had issues with the finish cracking and flaking away is this common if so how do you get around it? Link to comment Share on other sites More sharing options...
thefatman Posted July 6, 2010 Report Share Posted July 6, 2010 You'll need to change the bearings, knocking them out damages them, and new ones are very cheap. http://simplybearings.co.uk/shop/ This has a handy calculator to tell you what bearing type you need, if you go to your local bearing shop they'll be about half the cost compared to the site but its only a few quid either way. £70 is ok, its £20 a wheel round here if you pay cash. Link to comment Share on other sites More sharing options...
tonk Posted July 6, 2010 Author Report Share Posted July 6, 2010 Cheers guys. I presume there is a guarantee with this sort of work if cracking and flaking occur? Can't decide what colour and finish now. Bugger. Over to the general thread... Link to comment Share on other sites More sharing options...
bignige Posted July 6, 2010 Report Share Posted July 6, 2010 the better guys will mask/ plug threads etc most of them know to do it but maybe lazy, so tell them! Link to comment Share on other sites More sharing options...
roastdinajima Posted July 7, 2010 Report Share Posted July 7, 2010 Cracking/flaking is usually a result of the coating being under-cured or the coating being to thick. Make sure if your coater is masking the bearing/disc mounting faces they use a heat proof tape, trying to remove normal masking tape after its been baked on will give fecking nightmares. Fine scratches will be more noticeable on gloss finishes than on satin or matt but they will all be as tough as one another. Link to comment Share on other sites More sharing options...
stubbsy Posted July 7, 2010 Report Share Posted July 7, 2010 On this topic, can anyone recommend sensibly priced powder coating in the somerset area??? Link to comment Share on other sites More sharing options...
alexp5 Posted July 7, 2010 Report Share Posted July 7, 2010 My local place charges £35 per bare wheel (no bearing or discs) for a solid colour, up to £80 per wheel for fancy special effect powders. Some of the powders they use are as good if not better than custom paint effects, and they mask off threads and bearing faces too. http://www.stpcoatings.co.uk/?page=about_us Link to comment Share on other sites More sharing options...
