Bat Fastard Posted June 30, 2010 Report Share Posted June 30, 2010 Morning Peps, I have put a hole in an outer engine case ( alternator cover) and need a decent welder/firm that can weld it up for me. Its an aluminium case. Hole is about 1 cm by 2cm in size. Anyone know of a decent firm/workshop that can do this for me around the surrey/berkshire area? Thanks in advance. Link to comment Share on other sites More sharing options...
Bat Fastard Posted July 1, 2010 Author Report Share Posted July 1, 2010 Anyone? Link to comment Share on other sites More sharing options...
mgtkr1 Posted July 1, 2010 Report Share Posted July 1, 2010 bound to be one near you, go to a bike meet or race meet and ask someone who owns older/quirky or special stuff. up here we have roy marriot aka forge welding. used to do rob macs stuff aswell as having a contract with the national motorcycle museum, quality is second to none. do you have a pic? possibly use chemical putty, jb weld is good. we use it inside the crankcases so its strong.is it visible? and what bike is it? Link to comment Share on other sites More sharing options...
cagimaha Posted July 1, 2010 Report Share Posted July 1, 2010 Another option is to try any local collecges/universities offering tech courses because the tutor will probably be able to sort something out. Link to comment Share on other sites More sharing options...
banoffee Posted July 1, 2010 Report Share Posted July 1, 2010 I think scotty/rescogs knows someone who lives in Ashford, Surrey that does ally welding... Link to comment Share on other sites More sharing options...
Gregorious77 Posted July 1, 2010 Report Share Posted July 1, 2010 I can weld ali but am not near you. some engine cases can be a pain to weld though due to the material. Link to comment Share on other sites More sharing options...
alexp5 Posted July 2, 2010 Report Share Posted July 2, 2010 I can weld ali but am not near you. some engine cases can be a pain to weld though due to the material. This^^^. Cast aluminium is rarely just aluminium, there can be allsorts of crap thrown in with it. Best bet would be to braze it. Try it yourself... all you need are some HTS2000 or Durafix aluminium brazing rods and a MAPP gas or turbo tip torch. If this sounds scary... there's a bodge that I've used in the past that works well: If you have enough clearance from inside the cover, you can use a piece of ally mesh to bridge the hole. Drill and tap two small holes either side of the hole and screw the mesh down. You can file or linish the screws down if they protrude out the front of the cover, then use some Devcon putty over the mesh to fill the hole, screws an' all. Link to comment Share on other sites More sharing options...
speedy sie Posted July 2, 2010 Report Share Posted July 2, 2010 Devcon putty use this at work for emergance repaires,we have a rew diferent types,wet repaire,titanium repaire and a few other types,i would recomend this to every one as it sets rock hard. a dit dear but you pay for wot you get. Link to comment Share on other sites More sharing options...
bigkev Posted July 2, 2010 Report Share Posted July 2, 2010 Bat Fastard What bike is the engine off? I have welded a few succsesfully before if you want to post it I can throw some alloy on it for you. Kev Link to comment Share on other sites More sharing options...
Bat Fastard Posted July 3, 2010 Author Report Share Posted July 3, 2010 Thanks for the replies/offers. I thought about some sort of liquid metal but thought getting it welded would be better. Its the alternator casing on a 996. Hole is on the edge of the case just above the location of the sprocket. I will see what I can get sorted. Link to comment Share on other sites More sharing options...
Superdunc Posted July 3, 2010 Report Share Posted July 3, 2010 I have a spare alt cover for a 996, it has been welded before and is a bit scruffy, but is sound and oil tight, it's yours if you pay the postage. Duncan. Link to comment Share on other sites More sharing options...
