Inbred Posted June 29, 2010 Report Share Posted June 29, 2010 I know everything is probably OK but have had the battery out of the bike for a couple of days. Paranoia has kicked in about the PCIII, does it re-set if not powered for a while. I don't have the custom map, the local dyno does and i won't be able to get over there to get it re-mapped. ta. Link to comment Share on other sites More sharing options...
banoffee Posted June 29, 2010 Report Share Posted June 29, 2010 not had a prob when done this in the past. perhaps you could ask the dyno place to email you the map. Link to comment Share on other sites More sharing options...
banoffee Posted June 29, 2010 Report Share Posted June 29, 2010 http://www.powercommander.com/powercommand...er_faqs.aspx#36 Link to comment Share on other sites More sharing options...
Inbred Posted June 29, 2010 Author Report Share Posted June 29, 2010 http://www.powercommander.com/powercommand...er_faqs.aspx#36 Mr banoffee Thank you very much for your help. Why is it when I am faced with a problem I loose the ability to think or use common sense. Thanks again Link to comment Share on other sites More sharing options...
