thefatman Posted June 26, 2010 Report Share Posted June 26, 2010 Does anyone know the standard setting fro a K7 600/750 shock, and which is the high speed/low speed adjuster. Link to comment Share on other sites More sharing options...
lorenzo Posted June 26, 2010 Report Share Posted June 26, 2010 Woah! You made a venture out of the 80's/90's? Shocking stuff! Link to comment Share on other sites More sharing options...
Phil Norton Posted June 26, 2010 Report Share Posted June 26, 2010 If no-one else gets back to you with the info, I'll be able to post early in the week when Marisa gets back from a weekend away. I had a quick look for the manual to her bike earlier, but I'll be fucked if I can work out where she's put it. All my paperwork just sits in one big pile in a cupboard, but she's got some sort of system that I can't work out. Link to comment Share on other sites More sharing options...
Gobert Posted June 26, 2010 Report Share Posted June 26, 2010 SUSPENSION SETTING After installing the rear suspension, adjust the spring pre-load and damping force as follows. SPRING PRE-LOAD ADJUSTMENT The set length 176.4 mm (6.94 in) provides the maximum spring pre-load. The set length 186.4 mm (7.34 in) provides the minimum spring pre-load. STD length: 181.4 mm (7.14 in) DAMPING FORCE ADJUSTMENT Rebound side Turn the damping force adjuster clockwise fully. It is at stiffest position and turn it out to standard setting position. STD position: 1 1/2 turns out from stiffest position [Fine-tune the adjuster by turning it slightly until two punch marks align.] Low speed Compression side Turn the damping force adjuster clockwise fully. It is at stiffest position and turn it out to standard setting position. STD position: 1 3/4 turns out from stiffest position [Fine-tune the adjuster by turning it slightly until two punch marks align.] High speed Compression side Turn the damping force adjuster clockwise fully. It is at stiffest position and turn it out to standard setting position. STD position: 3 turns out from stiffest position [ Standard suspension setting REAR Spring set length 181.4 mm (7.14 in) Rebound 1 1/2 turns out from stiffest position Low speed comp side: 1 3/4 turns out from stiffest position High speed comp side: 3 turns out from stiffest position Link to comment Share on other sites More sharing options...
funkyphil Posted June 28, 2010 Report Share Posted June 28, 2010 This was posted on Gixxer.com - can't guarantee the file is still there but... GSXR 600 K6/7 Manual ..and I found this video really useful for setting up the shocks and forks, handily demonstrated on a GSXR 600 (its a K8 but the adjusters are pretty much the same).. http://www.onthethrottle.com/content/view/73/73/ Hope this helps Link to comment Share on other sites More sharing options...
thefatman Posted June 28, 2010 Author Report Share Posted June 28, 2010 Thanks guys, just watched the video now and all is explained Link to comment Share on other sites More sharing options...
