alexp5 Posted May 27, 2010 Report Share Posted May 27, 2010 I don't normally lurk around these parts, but I need to ask a favour of the PB Stroker Massive I'm after some measurements, in MM's, of end can dimensions. Namely length, diameter, and especially the i.d. of the inlet pipe (this needs to be fairly accurate, so if you have Verniers... even better). Any flavour of can will do... TZR, RGV, 125, 250, etc. it doesn't really matter. So if any of you have the said items lurking in your sheds, I'd appreciate it if you could get the tape measure out for a minute or so and let me know of your findings. Thanks all Link to comment Share on other sites More sharing options...
wazrs257 Posted May 27, 2010 Report Share Posted May 27, 2010 Hi. Try these links, they're race cans, but should give you an idea. http://www.2moto.co.uk//index.php?option=c...0&Itemid=41 http://www.fondseca.com/index.php?main_pag...products_id=811 Hope this helps. Link to comment Share on other sites More sharing options...
