speedy sie Posted May 22, 2010 Report Share Posted May 22, 2010 due to the fact iv seen three electrical problems on the forum aver the winter/spring period ill write a check list for the beloved srad,this will be an ongoing list as i can be botherd to update the problems. im no going to state the bloody oviouse electrical prolblems only the ones for the srad.if you get a check falut on the clocks then go to the rear lift the main seat and find the small white plug with the rubber cover,jump the two (this plug has only two)conection over with a small peice of wire and a fault code will come up on the dash unit,here is the list and will help find the problem. C14 - THROTTLE POSITION SENSOR C15 - ENGINE COOLANT TEMPERATURE SENSOR C21 - INTAKE AIR TEMPERATURE SENSOR C22 - ATMOSPHERIC PRESSURE SENSOR C23 - TIPOVER SENSOR C24 - IGNITION SIGNAL #1 C25 - IGNITION SIGNAL #2 C26 - IGNITION SIGNAL #3 C27 - IGNITION SIGNAL #4 C28 - SECONDARY THROTTLE VALVE ACTUATOR C29 - SECONDARY THROTTLE POSITION SENSOR C30 - SECONDARY THROTTLE CONTROL UNIT C31 - GEAR POSITION SENSOR C32 - INJECTOR SIGNAL #1 C33 - INJECTOR SIGNAL #2 C34 - INJECTOR SIGNAL #3 C35 - INJECTOR SIGNAL #4 C41 - FUEL PUMP CONTROL SYSTEM C42 - IGNITION SWITCH SIGNAL and the later gsxr codes “C11” (P0340) CMP SENSOR CIRCUIT MALFUNCTION “C12” (P0335) CKP SENSOR CIRCUIT MALFUNCTION “C13” (P0105-H/L) IAP SENSOR CIRCUIT MALFUNCTION “C14” (P0120-H/L) TP SENSOR CIRCUIT MALFUNCTION “C15” (P0115-H/L) ECT SENSOR CIRCUIT MALFUNCTION “C21” (P0110-H/L) IAT SENSOR CIRCUIT MALFUNCTION “C22” (P1450-H/L) AP SENSOR CIRCUIT MALFUNCTION “C23” (P1651-H/L) TO SENSOR CIRCUIT MALFUNCTION “C24” (P0351), Coil #1IGNITION SYSTEM MALFUNCTION “C25” (P0352), Coil #2 “C26” (P0353) Coil #3 “C27” (P0354) Coil #4 “C28” (P1655) Secondary TV ACTUATOR CIRCUIT MALFUNCTION “C29” (P1654-H/L) Secondary TP SENSOR CIRCUIT MALFUNCTION FI SYSTEM DIAGNOSIS “C31” (P0705) Gear Position SWITCH CIRCUIT MALFUNCTION “C32” (P0201), #1PRIMARY FUEL INJECTOR CIRCUIT MALFUNCTION “C33” (P0202), #2 “C34” (P0203) #3 “C35” (P0204) #4 “C36” (P1764), # 1 SECONDARY FUEL INJECTOR CIRCUIT MALFUNCTION “C37” (P1765), #2 “C38” (P1766) #3 “C39” (P1767) #4 “C41” (P0230-H/L) FP RELAY CIRCUIT MALFUNCTION “C42” (P01650) IG SWITCH CIRCUIT MALFUNCTION “C44” (P0130/P0135) HO2 SENSOR (HO2S) CIRCUIT MALFUNCTION (For E-02, 19) “C46” (P1657-H/L or P1658) EXCV ACTUATOR CIRCUIT MALFUNCTION “C49” (P1656) PAIR CONTROL SOLENOID VALVE CIRCUIT MALFUNCTION “C60” (P0480) COOLING FAN RELAY CIRCUIT MALFUNCTIO check the code and ill put some ideas as to were the pfoblem is. C14never had a problem with the throttle posiosion swich,only ever seen one come lose,but have seen them played with. C15. water tem unit,ither has a fault with the tep unit(iv never had this happen),or the loom to the clocks or the clocks. the most likley cause is the green block under the left ram tube is corodded,come undone,damaged.this plus also does the rev counter,so problems there could also be this plug. Link to comment Share on other sites More sharing options...
jaycee Posted May 22, 2010 Report Share Posted May 22, 2010 Ah Sie, I was looking at this plug yesterday but I didn't know the fault codes and their meanings. Cheers Big Fella Link to comment Share on other sites More sharing options...
