Devon Posted May 4, 2010 Report Share Posted May 4, 2010 does anyone know where i can get some 90 degree tyre valves? the only ones I have found are expensive Link to comment Share on other sites More sharing options...
bignige Posted May 4, 2010 Report Share Posted May 4, 2010 http://www.mandp.co.uk/productsList.aspx?s...;kw=tyre+valves scroll down for the cheapies! or try ur local dealer. hth Link to comment Share on other sites More sharing options...
kawaman21 Posted May 5, 2010 Report Share Posted May 5, 2010 try demon tweeks bridgeport 90 degree valves about £10 for 2, 11.3mm for jap wheels Link to comment Share on other sites More sharing options...
Cibbersicks Posted May 5, 2010 Report Share Posted May 5, 2010 Don't scrimp and buy the ones that adapt to your current 'conventional' valves, they are wobbly as fuck and when the wheel spins up to 70mph+ there are some serious forces acting on the rubber valve base, which it's not designed to handle, and whill eventually end up releasing pressure...fast. Go for the ones which are solid and completely replace your current valves, like these: Trick valves I may be looking into a set of these, thanks for reminding me! Link to comment Share on other sites More sharing options...
