addiction269 Posted April 25, 2010 Report Share Posted April 25, 2010 My mille fans didnt cut in and the temperature was 108 degrees while sat in traffic - any help??? Link to comment Share on other sites More sharing options...
spacemonkey Posted April 25, 2010 Report Share Posted April 25, 2010 My mille fans didnt cut in and the temperature was 108 degrees while sat in traffic - any help??? They do get worryingly hot before the fans come on..... I wired up a switch to mine so I could turn them on/off myself. You can buy lower temperature thermal switches too..... Link to comment Share on other sites More sharing options...
addiction269 Posted April 25, 2010 Author Report Share Posted April 25, 2010 They do get worryingly hot before the fans come on..... I wired up a switch to mine so I could turn them on/off myself. You can buy lower temperature thermal switches too..... It was reading 108, way too high i reckon! gotta check the system me thinks. Where can you get the switches? cheers Link to comment Share on other sites More sharing options...
spacemonkey Posted April 25, 2010 Report Share Posted April 25, 2010 It was reading 108, way too high i reckon! gotta check the system me thinks. Where can you get the switches? cheers http://www.af1racing.com/store/Scripts/pro...?idproduct=4522 Link to comment Share on other sites More sharing options...
addiction269 Posted April 25, 2010 Author Report Share Posted April 25, 2010 I would expect the fan to come on at 103! Need to get the fan switches off and get them immersed in something that heats up higher than 110, see if the switches do work. YOu could also try measuring the temp of the rad and water hoses with one of those infra-red temperature gun things, to make sure the temperature sensor isnt giving you a false reading Yeah that what i thought, gotta get it sorted soon! Hot weather is here now lol Link to comment Share on other sites More sharing options...
millerich Posted April 25, 2010 Report Share Posted April 25, 2010 Temperature sensor failed most likely. Mine failed a couple of years ago. Noticed the temp guage reading 120 as I got into the tunnel train on the way to the Ring. Arse! Normally mine comes on at 95. Speedaway had the part in stock then and may well still now. Easy to change. Check your fuses obviously and you can bridge the contacts on the sensor to see if that will switch the fans on. Link to comment Share on other sites More sharing options...
rsv chris Posted April 25, 2010 Report Share Posted April 25, 2010 Mine comes on at 95 also. Everytime. When it's working! Link to comment Share on other sites More sharing options...
addiction269 Posted April 26, 2010 Author Report Share Posted April 26, 2010 Mine comes on at 95 also. Everytime. When it's working! ive checked the fans and they turn went you put a current through, so now ive gotta find the temp switch, its all a bit hard to find due to a modified airbox hiding everything! Link to comment Share on other sites More sharing options...
millerich Posted April 27, 2010 Report Share Posted April 27, 2010 Parts diagram on Yorkshire Aprilia's website shows its location. Link to comment Share on other sites More sharing options...
