monty_zac Posted April 20, 2010 Report Share Posted April 20, 2010 Fitting a new pipe today, teh standard one has a stop welded in for the centre stand to rest on which the aftermarket one doesnt. So need to take the stand away, which doesnt bother me at all as I wouldnt use it anyway, but I just cant work out how it comes off? Only stuff I can find on the web is pre-99 ones which have a split pin and a bolt at the other end. The fische doesnt show a stand for the 99-2001 model as I think it was euro spec only. Any ideas? Link to comment Share on other sites More sharing options...
blow_away Posted April 20, 2010 Report Share Posted April 20, 2010 Seems a bit wierd Dave? Sorry no real idea, except for this Link to comment Share on other sites More sharing options...
monty_zac Posted April 20, 2010 Author Report Share Posted April 20, 2010 Seems a bit wierd Dave? Sorry no real idea, except for this Its going to come to that!! Link to comment Share on other sites More sharing options...
szrdave Posted April 21, 2010 Report Share Posted April 21, 2010 I took the stand off my F1 a couple of weeks ago for the same reason, I think they're pretty much the same. IIRC: 1 - With exhaust off lift stand all the way up to release tension on spring, remove spring. 2 - Use 10mm (I think) socket to undo and remove the top spring mount (that you've just taken the spring off). This is what holds the stand retaining bar in. 3 - Undo gear linkage --> output shaft pinch bolt and drop linkage down (to give clearance for step 4). 4 - Drift stand pivot/retaining bar out from RHS of bike. 5 - Re-attach gear linkage. Simple as that! My stand was a bit rusty and seized, but came off a lot easier than I expected Link to comment Share on other sites More sharing options...
monty_zac Posted April 21, 2010 Author Report Share Posted April 21, 2010 Cheers Dave, that makes sense, I guess the pivot bar wont come out as its under loads of tension with the spring on there. Will give that a go. Link to comment Share on other sites More sharing options...
szrdave Posted April 21, 2010 Report Share Posted April 21, 2010 I didn't word it very well, the spring mount actually bolts through the end of the bar to hold it in place. You'll see what I mean when you look at it. The bike looks a lot tidier with the centre stand removed, but I would have liked to keep it if I could. There is something perversely satisfying (maybe it's just me!) about coming in from a session on track and popping it on the main stand Link to comment Share on other sites More sharing options...
monty_zac Posted April 27, 2010 Author Report Share Posted April 27, 2010 Right sorted it. It was as Dave said, once the spring is off you can see a 12mm bolt, once this was removed the stand just about fell off, sorted!! New can on, happy monty Link to comment Share on other sites More sharing options...
Harry Muff Posted April 27, 2010 Report Share Posted April 27, 2010 Right sorted it. It was as Dave said, once the spring is off you can see a 12mm bolt, once this was removed the stand just about fell off, sorted!! New can on, happy monty The difference a quality can makes to a bike... Bet it sounds nice too. Link to comment Share on other sites More sharing options...
