Rammy Posted April 19, 2010 Report Share Posted April 19, 2010 Friend of a friend has had a chain jump off his thundercat taking the pushrod for the clutch with it. I have had a quick look and the hole has a slight oval (the crank casting) and the seals goosed. The pushrod is balls deep in the engine anybody pulled one out? if so what method was the best (before i start making a fool of myself) im assuming they do just pull out as the manual online mentions removing to check straightness. Was going to have a bash at long fine drill and small tap/drill in and pull out with same bit. Im not sure even if it does come out that a new shaft and seal will work but its got to worth a try before we look at replacing a bottom end casting. Input please!!!!! Cheers Simon Link to comment Share on other sites More sharing options...
chrisexup Posted April 19, 2010 Report Share Posted April 19, 2010 if you remove the clutch you can tap it out from that side. You may be able to get a thin drift on it without removing the basket, just the plates, short pushrod, and ball bearing? Link to comment Share on other sites More sharing options...
