Kayla Posted April 18, 2010 Report Share Posted April 18, 2010 My boyfriend's Buell has a snapped exhaust stud on the front pipe, and there's enough room to get a drill in to drill it out. There's no thread showing outside the head so he can't get anything to grip on it, and we're kind of at a loss as to how it happened really. has anyone used a bolt extractor to remove a snapped stud before without it snapping in the head? What about a left-hand drill bit? Thanks Link to comment Share on other sites More sharing options...
tootall Posted April 18, 2010 Report Share Posted April 18, 2010 Gonna have to drill it out. Have a go with an easy-out, but be prepared for the nightmare that is a snapped easy-out, so if it feels like the easy-out is going to snap, give up with that and just drill the studd fully out and fit a heli-coil or tim-sert. Take your time, and don't force anything or this could prove to be a nightmare. If you're careful it's all pretty straightforward. Link to comment Share on other sites More sharing options...
porter_jamie Posted April 18, 2010 Report Share Posted April 18, 2010 it's a shit job cos the stud is harder than the ally, and ideally you need to get the snapped bit of the stud flat, centre dot it and drill it out so you dont have the drill wandering off and mullering the head. good luck if you are totally in the shit, my old man has a spark eroder that is ideal for removing snapped eaziouts etc you can get left handed colbalt or carbide drills, try cromwell or j an l http://www.axminster.co.uk/product-Axminst...-Set-462398.htm axminster do a colbalt/ezeout kit for 8 quid, worth a punt Link to comment Share on other sites More sharing options...
Kayla Posted April 18, 2010 Author Report Share Posted April 18, 2010 We got some extractors today but to be honest, I'm not hopeful. It's my bf's bike and I'm not going anywhere near it unless he specifically asks me to do something. It's an imperial thread too On the bright side, the other stud came out ok so he can still get the header clamped up alright, and the headers are held in place by each other so they're not going anywhere. I dunno. At least with Japanese bikes you know the bolts and nuts are cheese, but at least they're metric cheese. Thanks for your replies, I'll pass it on. You don't have a large bag of patience to spare, do you? Link to comment Share on other sites More sharing options...
Adam Posted April 18, 2010 Report Share Posted April 18, 2010 I've taken out quite a few snapped studs and bolts by welding a nut onto what's left of it. It works great. Even if it's snapped off flush. We got some extractors today but to be honest, I'm not hopeful. It's my bf's bike and I'm not going anywhere near it unless he specifically asks me to do something. It's an imperial thread too On the bright side, the other stud came out ok so he can still get the header clamped up alright, and the headers are held in place by each other so they're not going anywhere. I dunno. At least with Japanese bikes you know the bolts and nuts are cheese, but at least they're metric cheese. Thanks for your replies, I'll pass it on. You don't have a large bag of patience to spare, do you? Link to comment Share on other sites More sharing options...
Inbred Posted April 18, 2010 Report Share Posted April 18, 2010 This link below (might have to cut and paste to browser) provides some step by step instruction. http://www.asashop.org/autoinc/may2003/techtotech.htm Whilst these sort of instructions can be patronising, it can be a good way of working through the task in an ordered fashion with useful hints along the way. Although it always ends with me reaching for my biggest hammer. good luck. Link to comment Share on other sites More sharing options...
Harry Muff Posted April 18, 2010 Report Share Posted April 18, 2010 Drilling sounds the only option really. And might I suggest a bit of this: Link to comment Share on other sites More sharing options...
heds954 Posted April 18, 2010 Report Share Posted April 18, 2010 Have a go with an easy-out, but be prepared for the nightmare that is a snapped easy-out, so if it feels like the easy-out is going to snap, give up with that and just drill the studd fully out and fit a heli-coil or tim-sert. DON'T USE AN EASYOUT!!! Fuggin things are made from glass not metal, fuggin useless things... *grumble, grumble* don't ask me how I know In hindsight I'd have used carbide drillbits, centred properly and work your way up from small to correct size, drilling slowly and using cutting fluid. Good luck, you'll need it Link to comment Share on other sites More sharing options...
lorenzo Posted April 18, 2010 Report Share Posted April 18, 2010 If you can ride the bike then I'd take it somewhere where they could weld a thingy or a whatsisname on it. Not only will that give you something to undo, but critically, you'll only be fucking about with the stud and not the head, plus the heat of the welding will most likely shock the stud free anyway. Link to comment Share on other sites More sharing options...
Kayla Posted April 19, 2010 Author Report Share Posted April 19, 2010 Weeeellll... He finally thought it through and just put the collar back on with a washer under the nut on the (good) stud to hold it down tight enough to get it to an engineers' to get it removed with someone else's expertise. It's probably going to Armstrong's in Newcastle. Link to comment Share on other sites More sharing options...
