Dynojet Quickshifter setup
Fudd
Posted
Just a quick question. When in the setup menu on the laptop, you can adjust the kill time for each gear, which as I understand it, refers to the amount of time the ignition is cut during each shift. The standard values are around 65ms for first to second dropping to 50ish for fifth to sixth.
But there is also an activation time to adjust, the standard time being 250ms. So what is this activation time, or what part of the shift operation does it refer to? :o
Me confused ;)
tia
