1%er Posted April 4, 2010 Report Share Posted April 4, 2010 ok this problem is screwing with my head removed battery from my 929 blade because it was dead and charged it up using one of those cheapy aldi jobs when i try to reconnect it up it keeps blowing the 30 amp fuse WTF is going on Link to comment Share on other sites More sharing options...
ronenige Posted April 4, 2010 Report Share Posted April 4, 2010 ok this problem is screwing with my head removed battery from my 929 blade because it was dead and charged it up using one of those cheapy aldi jobs when i try to reconnect it up it keeps blowing the 30 amp fuse WTF is going on Disconnect your reg/rec and try again ,its not unknown for them to go tits up ( technical term )hth Link to comment Share on other sites More sharing options...
gsxr renegade Posted April 6, 2010 Report Share Posted April 6, 2010 I had exactly the same problem as this a few months ago. It turns out that some of the wires coming from the reg rec had been rubbing on the frame and shorting out, blowing the main fuse. I just wrapped electrical tape around the wires, and hey presto, hasn't blown a fuse in months.* Now that i've said that, the fuse is garunteed to blow when i try and go home after work today. Link to comment Share on other sites More sharing options...
1%er Posted April 6, 2010 Author Report Share Posted April 6, 2010 cheers for the advice lads connected up the battery outa me race bike and bingo bango no problems checked for loose or exposed wires and couldnt see anything does not explain what the problem was tho but at least its running Link to comment Share on other sites More sharing options...
