rsv chris Posted March 22, 2010 Report Share Posted March 22, 2010 Well my bloody low oil pressure light comes on when the mille is on tick over. (rev the bike over 2k goes out) The bike doesn't knock or rattle either, sounds like usual. It's been leaking a few trickles of coolant recentley on to the pressure switch, I've taken the switch cover off and left it to dry out. Hoping water ingress has damaged the switch making it too sensitive if you will (clutches at straws, better be electrical!). I will be pretty pissed off if I need to change the oil pump on a 25000 mile bike! Is there any history off weak mille oil pumps? I'm going to buy a new switch anyway, if the fault is still aparent after copious drying time. But to ease/worry, my mind anyone got any gen? Link to comment Share on other sites More sharing options...
ronenige Posted March 22, 2010 Report Share Posted March 22, 2010 Switches are a bit crap , change it , you'll be reet ! if that dont work then it's bolloxed and i'll give you a fiver for it Link to comment Share on other sites More sharing options...
Jay Posted March 23, 2010 Report Share Posted March 23, 2010 Have you checked the oil level properly? With it being a dry sump engine (with a 2 stage oil pump) the oil level is critical for achieving oil pressur at low rpm. +1 its not the regular way of checking the oil level and I have seen that happen before. Link to comment Share on other sites More sharing options...
rsv chris Posted March 23, 2010 Author Report Share Posted March 23, 2010 Cheers guys, the oil level is good, I change it two, three times a year, and it was the first thing I checked. Hopefully the switch then Link to comment Share on other sites More sharing options...
madmike Posted March 23, 2010 Report Share Posted March 23, 2010 Bloody Italians Link to comment Share on other sites More sharing options...
rsv chris Posted March 23, 2010 Author Report Share Posted March 23, 2010 Bloody Italians Well I can't argue! It is Italian and it has an electrical problem "hopefully". I can surely say, if it is the oil pump that has gone, no way am I going to look into buying an RSV4. Link to comment Share on other sites More sharing options...
spacemonkey Posted March 23, 2010 Report Share Posted March 23, 2010 Well I can't argue! It is Italian and it has an electrical problem "hopefully". I can surely say, if it is the oil pump that has gone, no way am I going to look into buying an RSV4. Hehe.. I don't think you can blame the italians on this one! All the electrics seem to be Japanese (Denso, etc) and all the motor bits are Austrian! (Rotax) Link to comment Share on other sites More sharing options...
rsv chris Posted March 23, 2010 Author Report Share Posted March 23, 2010 This is true, the engine is austrian, but the RSV4 has a " in house designed and fabricated engine" according to aprilia. If rotax make dodgy oil pumps ( hopefully not) then what is the chance of aprilia building a reliable new v4?? Hope it is reliable because I still would love one. Link to comment Share on other sites More sharing options...
ronenige Posted March 23, 2010 Report Share Posted March 23, 2010 IIRC the oil pressure at tickover is only around 15psi and the switches go off at 1 bar ( 14.7 psi ) so its pretty close , stick a switch on it , she'll be fine . Contact Griff at Aprilia performance ( 01827 285500 ) and tell him your problems and he'll probably stick a switch in the post for you http://www.apriliaperformance.co.uk/ Link to comment Share on other sites More sharing options...
rsv chris Posted March 23, 2010 Author Report Share Posted March 23, 2010 Cheers for the link, good site. I'll give he bike a run when it's not raining, and see if my attempts at drying the switch have worked. If not I'll be on the blower for a new switch. Link to comment Share on other sites More sharing options...
