johnlc Posted March 19, 2010 Report Share Posted March 19, 2010 Has anybody here used these Lumiweld kits for repairing side casings ,mine has a small crack which needs seen to asap Link to comment Share on other sites More sharing options...
fran9r Posted March 19, 2010 Report Share Posted March 19, 2010 I've used a JB weld type stuff before...easy and no problems. Link to comment Share on other sites More sharing options...
bezzer Posted March 20, 2010 Report Share Posted March 20, 2010 I've used the Bernzomatic alloy soldering rods (from B&Q) and it worked fine on casings, also used it to "weld" pieces together again with no problem. It's only £5 ish for two rods, cheaper and easier to used than Lumiweld, doesn't need "activating" with stainless steel like Lumiweld either. Link to comment Share on other sites More sharing options...
johnlc Posted March 21, 2010 Author Report Share Posted March 21, 2010 I've used the Bernzomatic alloy soldering rods (from B&Q) and it worked fine on casings, also used it to "weld" pieces together again with no problem. It's only £5 ish for two rods, cheaper and easier to used than Lumiweld, doesn't need "activating" with stainless steel like Lumiweld either. What type of blowtorch did you use Link to comment Share on other sites More sharing options...
kwakbiker Posted March 21, 2010 Report Share Posted March 21, 2010 Ive used a kit called techno weld, think I got it from demon tweeks, good stuff, used it to repair a rad with good results Link to comment Share on other sites More sharing options...
