Do dymags have captive spacers?
will#224
Posted
If so does anyone have pictures of how they have been made captive?
Posted
yes they are captive spacers - well they are on mine, but I'm guessing that's common across all their wheels
this is the only pic I've got handy. The spacers form part of the hub
Posted
It's always a source of headscratching the motorbike manufacturers still don't do this on standard wheels.
Posted
yep, all the dymags we have have captive spacers, they are ally tophats pressed into the bearing (so the bearing i/d has to be bigger than the spindle diameter)
Posted
got them on my wheel,ill send you some pics if you want?
Please.
I have a rough idea of how they've done it.
I've seen a wheel recently with a top hat spacer and a circlip holding the top hat to the bearing. Seemed to work well and an easy fix but essentially the larger bearing ID and spacer pressed into seems like a simple option too.
Posted
no the insert(top hat)goes in to the iner race of the bearing(wich is over sized iner diamiter to acomidate the insert)then the same on the iner spacer(between the two bearings),then the same on the other bearing,in esance samwedgeing the bearing to the forks,or swaing arm.then the pin goes through to compleat the proces.
circlip?
Posted
circlip?
The circlip featured on a homemade captive spacer set up.
Posted
iv got a set of dymags for sale,dark grey,off a gsxr100.
Is that like a RXS100 but quicker ?
Posted
upsss.....gsxr10000! mised a 0' out. :rolleyes:
Posted
Now you've got an extra one ;)
hmm... 10 litre gixxer..... I'd have one as long as it was oil-cooled and not one of those namby-pamby modern water cooled things
Posted
They are required for a 400 otherwise i'd be interested
