LED Indicators
paul8899
Posted
hello,
bought some oxford led indicators ( the ones with the resistors included ) and I am having a bit of trouble with them. I have fitted the front set ( with resistors ) and the flash rate is normal , but when I plug in the rear set the flash rate speeds up , I have tried it with and without the resistor and it makes no difference . The strange thing is when I wire it in with the bulb indicator,without the resistor ( 2 rear and one front indicator ) the flash rate is normal , they only speed up when its the led ones . I haven't tried having the resistor only on the rear ones to see what happens
do you need one resistor per indicator or is it one per side ?
any help would be appreciated
thanks
Posted
Like Motrax, I presume Oxford will sell you an appropriate flasher unit for use with LEDs...but if the resister is supposed to let it work automatically, then have a word with them.
Sound like they are having no effect -the when you use just a pair of LEDs, that's what happens.
Posted
the resistors work when its the led fronts and normal rears but when its both they speed up , wierd !
Ill drop em an email and see what they say
Posted
With the ones I've got you need one resistor per indicator.
Posted
Swap the front and backs around to see if it's a duff indicator or resistor.
Posted
I've found that the resistors are needed on each LED. Then, about 200 miles down the road, the brittle wire that comes out of the resistor will snap off, right where it goes into the resistor itself, meaning you can't bodge it back together, and you then have to buy a led compatible flasher relay. Bollocks, isn't it.
Posted
tried different resistors and indicators , all the same :eusa_whistle:
also tried standard front and led rear , those worked ok , just cant get front and rear leds to flash properly
looks like ill be buying one of those plug in relays soon
Posted
just had a look through the demon tweeks book and there are 2 types of relay , the motrax one and a 2 or 3 pin , any ideas as to which one to get ?
Posted
Motrax do a manufacturer specific one...I'd get one of them. If DT don't list it, then go to a Motrax dealer.
