Kawasakifreak Posted February 13, 2010 Report Posted February 13, 2010 Hi, Anyone recommend a good manufacturer for the above - hoses & clutch cable too short for my raised bars even after re-routing ?
wesifume Posted February 14, 2010 Report Posted February 14, 2010 VenHill The pieces for the brake lines come in various angles so you get the correct fit that you want. Order the length you want. The fittings screw together so that you can adjust and readjust until you are happy. Quality pieces of kit.
Kawasakifreak Posted February 14, 2010 Author Report Posted February 14, 2010 Gimme a pm with what you need. What's a 'pm' ?
Kawasakifreak Posted February 14, 2010 Author Report Posted February 14, 2010 VenHill The pieces for the brake lines come in various angles so you get the correct fit that you want. Order the length you want. The fittings screw together so that you can adjust and readjust until you are happy. Quality pieces of kit. Thanks Wesifume - how did you add nipples to your cables - soldering or another method ?
lorenzo Posted February 15, 2010 Report Posted February 15, 2010 What's a 'pm' ? On the, by peoples names, there's a little arrow thing, click there, and a menu will come down, one of which is 'send personal message': That's a PM.
