Kawasakifreak Posted February 5, 2010 Report Share Posted February 5, 2010 Appreciate any advice re. the above ? Space appears tight between engine & tank. Any photos of completed ZX7R Streetfighter harness routing would be great. Link to comment Share on other sites More sharing options...
tootall Posted February 5, 2010 Report Share Posted February 5, 2010 The bit of loom you've got in your hand there goes under the left frame spar, up behind the headstock. As far as I remember it then heads out through the hole on the right hand side, the opposite one to the hole the throttle cables run through. Link to comment Share on other sites More sharing options...
gurninman Posted February 5, 2010 Report Share Posted February 5, 2010 Or you could create a wormhole beneath the tank and then have the wiring reappear wherever you want Link to comment Share on other sites More sharing options...
