One for the ZX9r fans.
exuprob
Posted
Ive got a set of carbs that I need to know which model bike they're from.
This is what I know........
They are 40mm Keihin carbs with CVK stamped on them.
They have a throttle pot at one end.
They have a bump in both sides of the CV slides so aren't semi flat but are CV carbs.
They have restricted carb tops so the slide only goes 3/4 up.
I'm pretty sure they are from a ZX9r but not sure which model or year.
Any ideas????????
Posted
If the carb tops are restricted then it'll be a B1 or 2 model......
Posted
Lovely job, thanks for that.
Does that mean ZX7 carb tops will fit to derestrict them?
Posted
or if your careful you can modify the existing caps to let the carbs open fully
