speedy sie Posted February 4, 2010 Report Share Posted February 4, 2010 two sleves needed. two 1mm and two 1.5mm wall thickness 75mm in lengh a top lip of 4mm lip will be 1mm thick. after being spun up,will have a 2mm slot running down the length. Link to comment Share on other sites More sharing options...
Mark/Foggy Posted February 4, 2010 Report Share Posted February 4, 2010 We'll talk. Link to comment Share on other sites More sharing options...
speedy sie Posted February 4, 2010 Author Report Share Posted February 4, 2010 point noted,was a thinking about this as i could do it my self,but the old lath we have is nut up to this fine a cut , chuk is not that acurate as im sure it was used to build the bloody bouncing bomb as it is that old so might go with titanium....if eny body can help..or stainles if not, or another strong alioy? of even some plastic stuff,that pcf ? i asume the factory ones are magnesium? Link to comment Share on other sites More sharing options...
sennidott Posted February 4, 2010 Report Share Posted February 4, 2010 Here's one of Nick's, with XR0 magnesium yokes and early Kayaba forks. Note red anodised inserts around the fork legs. You would have to get Nick to measure his top yoke and then check the size of your top yoke to see if Nick's have been modified to suit the forks? A colourful selection of anodised parts there... Link to comment Share on other sites More sharing options...
speedy sie Posted February 4, 2010 Author Report Share Posted February 4, 2010 yes these arew the same yokes i have ,nick gave me the top red inserts,but the forks(ohlins)im getting will shim at the bottom aswell. ohhh.better get some bog roll,wot a pic... Link to comment Share on other sites More sharing options...
eddie Posted February 6, 2010 Report Share Posted February 6, 2010 I can do you some sleeves at work, but will obviously need the sizes of your forks, and the sizes of your yokes. Paul (PM Beek if youre concerned about me making them) Link to comment Share on other sites More sharing options...
