southwestbiker Posted February 3, 2010 Report Share Posted February 3, 2010 Right, does anyone know anything about the automatic shut off on the fuel tap/spout on a 96 SRAD fuel pump? Its doing my head in, and the search function on here wont let me search for "fuel tap" as it doesn't like 3 letter words. As far as i can remember, when i used to take the fuel pipe off the tank, there was never any leakage from the connection on the bottom of the tank. However when i decided to take the tank off at the weekend, i removed the pipe, and fuel came out like it was coming out a tap and wouldn't stop. Cue finger over the end and balancing it "just right" upside down to stop the leaking and a lot of fuel over the road outside. Anyone any ideas what to look for, i'm hoping its a stick float/valve or something similar, but i ain't got the foggiest? Anyone had a similar issue? Or of course, anyone wanna tell me I'm an idiot and it always did that? Cheers! Link to comment Share on other sites More sharing options...
lorenzo Posted February 3, 2010 Report Share Posted February 3, 2010 This is a complete guess as I've not probed my new bikes fuel tap too much, but doesn't it have a vacuum type arrangement which means it only flows if there's a vacuum on another hose from the carbs? I'm guessing there's a split diaphraghm in there somewhere, if this is the case. Link to comment Share on other sites More sharing options...
krazyk Posted February 4, 2010 Report Share Posted February 4, 2010 Hi,it's called a fuel valve in Haynes book and there is a test section in there basicaly:no fuel should flow without the ignition on and turning starter motor. So fuel flow is indicative of damaged diaphram. Book also states : replace complete unit, no internal parts available. I will however check the parts list later when I get on computer later. Keith Link to comment Share on other sites More sharing options...
southwestbiker Posted February 4, 2010 Author Report Share Posted February 4, 2010 Nice one, cheers guys! Am i going to have a problem if i just run the bike like it is, just being wary if i have to take the tank off when its full? Link to comment Share on other sites More sharing options...
lorenzo Posted February 4, 2010 Report Share Posted February 4, 2010 Don't know but I bet it's a straight swap for loads of other suzukis from the same era. I know when I had a problem with my trx the fuel tap was common to about 80% of the yamaha range, I'd imagine it'd be a similar scenario here. Link to comment Share on other sites More sharing options...
southwestbiker Posted February 5, 2010 Author Report Share Posted February 5, 2010 Righto, best get that fixed then! I tell you, when i bought this bike, i thought a 14 year old SRAD for £500 was to good to be true, now im starting to see the reality. Ah well, at least im getting around the bike and seeing bits of it i havent seen before! Thanks again for all the advice! Link to comment Share on other sites More sharing options...
krazyk Posted February 5, 2010 Report Share Posted February 5, 2010 fuel valve oe part nr. is 44300-33E00. also req´d is seal part nr. 44351-33E00 dont know how much they cost but wouldn´t be to much. I´ve searched obay and could only find fuel pump set complete, starting at around 15 quid. K Link to comment Share on other sites More sharing options...
southwestbiker Posted February 5, 2010 Author Report Share Posted February 5, 2010 Your a star, cheers K! Link to comment Share on other sites More sharing options...
