b1h karl Posted January 23, 2010 Report Share Posted January 23, 2010 with an fi bike how would you know if the injecters are out of balance...what would be the symptoms and what rev range would it show it self at its worst... cheers Link to comment Share on other sites More sharing options...
lorenzo Posted January 23, 2010 Report Share Posted January 23, 2010 Innjectors out of balance? They're usually fed by a common fuel rail so you'd have the same pressure along them all, unless one was knackered. If by injector balance, you mean the throttle bodies, then I'd imagine that the signs would be the same as unbalanced carbs: poor idling, hestitant pick-up etc. Link to comment Share on other sites More sharing options...
b1h karl Posted January 23, 2010 Author Report Share Posted January 23, 2010 Innjectors out of balance? They're usually fed by a common fuel rail so you'd have the same pressure along them all, unless one was knackered. If by injector balance, you mean the throttle bodies, then I'd imagine that the signs would be the same as unbalanced carbs: poor idling, hestitant pick-up etc. tks lorenzo,i definately mean throttle bodies Link to comment Share on other sites More sharing options...
Gixxerthou Posted January 24, 2010 Report Share Posted January 24, 2010 Right, first sign of the injectors needing balancing is usually rough running at very small throttle openings, so if you feel like the bikes about to stall going round a small roundabout, that could be the culprit... or it may be your TPS(Throttle Position Sensor) needs adjusting. In my experience throttle bodies need doing every couple of years. Luckily for me my mate has a set of gauges. Link to comment Share on other sites More sharing options...
b1h karl Posted January 24, 2010 Author Report Share Posted January 24, 2010 is the throttle sensor adjustment a shop job or a do at home job... Link to comment Share on other sites More sharing options...
speedy sie Posted January 24, 2010 Report Share Posted January 24, 2010 can be done at home,but you need the haynes bible,and an ameter.so unless you are pritey good with electrics...leave to the shop. Link to comment Share on other sites More sharing options...
Richy Posted January 25, 2010 Report Share Posted January 25, 2010 Can you use carb vacuum gauges for a ingection bike (03 zx6r etc)? Link to comment Share on other sites More sharing options...
speedy sie Posted January 25, 2010 Report Share Posted January 25, 2010 yarp. Link to comment Share on other sites More sharing options...
