711tattoo Posted December 16, 2009 Report Share Posted December 16, 2009 right ive got all but 1 rear disc bolts out so i can have the wheel powder coated, the last bolt just wont move and its started to round off have you any idea what the best way to remove this last bolt before i twat it with a big hammer lol Link to comment Share on other sites More sharing options...
deviant Posted December 16, 2009 Report Share Posted December 16, 2009 Get some heat on it - hot air gun or blow torch. The alloy wheel will expand more than the steel bolt, and bob's your uncle. As you're having it powder coated you don't even have to worry about buggering up the paint if you do use a torch. Link to comment Share on other sites More sharing options...
Gobert23 Posted December 16, 2009 Report Share Posted December 16, 2009 Get a shot of PlusGas penetrating/releasing fluid in there (if you can)... that normally does the trick for me. G Link to comment Share on other sites More sharing options...
thefatman Posted December 16, 2009 Report Share Posted December 16, 2009 Drill the head off, then you can take the disc off and grab the remaining thread with a pair of mole grips. Link to comment Share on other sites More sharing options...
Marb Posted December 16, 2009 Report Share Posted December 16, 2009 Loctite also can't stand heat, so if someone was over generous with the loctite that will loosen too. Link to comment Share on other sites More sharing options...
Evilchicken0 Posted December 16, 2009 Report Share Posted December 16, 2009 be a man use an angle grinder with gogles Link to comment Share on other sites More sharing options...
711tattoo Posted December 16, 2009 Author Report Share Posted December 16, 2009 be a man use an angle grinder with gogles haha you bet i have cheers all Link to comment Share on other sites More sharing options...
MonkeyJim Posted December 16, 2009 Report Share Posted December 16, 2009 This was posted on here recently, some good advice Link to comment Share on other sites More sharing options...
