riversbikes Posted November 30, 2009 Report Share Posted November 30, 2009 Hey all, I bought a 29000 km RC51 that has been sitting for awhile. Chain looks salvageable, but I've heard bad things happen when you soak an OEM O-ring chain in certain solutions... would like to try to get it in decent shape again... is Varsol a no-no? Not a fan of leaving gas/petrol lying open in the garage as well... any other suggestions? Link to comment Share on other sites More sharing options...
thefatman Posted November 30, 2009 Report Share Posted November 30, 2009 Parafin/kerosene should do the trick, if not its time for a new one. Link to comment Share on other sites More sharing options...
Evilchicken0 Posted November 30, 2009 Report Share Posted November 30, 2009 Yup - paraffin. I salvaged / cleaned mine with paraffin and a small paint brush ... and wire brushed the plates, then used white sprit to get the last of the muck off it. After than thorough chain lubing ... I use the silicon type Link to comment Share on other sites More sharing options...
2 smokes 4 ever Posted December 8, 2009 Report Share Posted December 8, 2009 Yup - paraffin. I salvaged / cleaned mine with paraffin and a small paint brush ... and wire brushed the plates, then used white sprit to get the last of the muck off it. After than thorough chain lubing ... I use the silicon type all the chains I've soaked in paraffin has drastically reduced their life, coz it has washed the grease out I've stopped doing it now. If I need to clean a chain, I submerge it in plain motor oil for a couple of weeks This does eventually lift off the dirt and crap use an old paint brush to help lift off the dirt I has even extended the life of some O-rings chains, that were needing an adjustment after every ride - after soaking in oil, they stopped needing adjustment (for a while)! a wire brush is the last thing you want to let anywhere near an O-ring chain - it'll damage the O-rings which lets the grease get washed out and then the chain is finished! Link to comment Share on other sites More sharing options...
