flashgordon69 Posted November 25, 2009 Report Share Posted November 25, 2009 Have just got a spare generator and rotor from ebay for almost naff all and am going to put it on the lathe and lighten it Im going down the shed in a minute to weigh it Has any one else done this? How much meat did you take off it? How did it all go? Its from a 98/03 R1 i think theyre all the same Link to comment Share on other sites More sharing options...
fran9r Posted November 26, 2009 Report Share Posted November 26, 2009 Dunno, but let us know the results with piccys please. Link to comment Share on other sites More sharing options...
cagimaha Posted November 27, 2009 Report Share Posted November 27, 2009 I've done it to a 350LC, it's a pretty common modification on LC's and 'valves. Allows the engine to spin up a bit quicker and also puts less stress on the crank. I took about 4mm from the total diameter I think. Don't take this as a given value though cos I imagine an R1 rotor is a fair bit slimmer than an LC one! Also its a good idea to keep an eye on it for cracks periodically after you've fitted it. Hope this helps, Ben. Link to comment Share on other sites More sharing options...
xtmito Posted November 27, 2009 Report Share Posted November 27, 2009 Lightening items like this should be done carfully so not to weaken them. also another consideration is that both generator end and clutch side should be lightened as not to alter the harmonics of the crank and cause fractures or fretting on tapers etc. but all said does make alot of difference especially to older vehicles where they are over engineered. Link to comment Share on other sites More sharing options...
flashgordon69 Posted November 30, 2009 Author Report Share Posted November 30, 2009 This is the before pic, havnt had time to get on the lathe yet Link to comment Share on other sites More sharing options...
flashgordon69 Posted November 30, 2009 Author Report Share Posted November 30, 2009 other side Link to comment Share on other sites More sharing options...
2 smokes 4 ever Posted December 8, 2009 Report Share Posted December 8, 2009 I did this with a 350 YPVS one, once! It broke into two pieces (an outer ring, and the centre peice which was still attached tot he crank) and took the stator with it Be very careful on how much and where you take it from Link to comment Share on other sites More sharing options...
