birdona Posted October 19, 2009 Report Posted October 19, 2009 any one know the answer to this as ineed to change it on the c1 and have a chance at an e1 cheapish but don,t want to get it wrong.thanks
fran9r Posted October 19, 2009 Report Posted October 19, 2009 No, but they will fit. You should also consider a ZX12R, or a 10R, or even the 6R of the same vintage. All are a bit longer, but the 9 needs this to turn properly anyway.
kwakbiker Posted October 22, 2009 Report Posted October 22, 2009 What fran said, also the E has a ride height adjuster on the top bolt so get that as well
fran9r Posted October 22, 2009 Report Posted October 22, 2009 What fran said, also the E has a ride height adjuster on the top bolt so get that as well E ride height adjuster has a threaded end to mount into the E frame, that won't fit on the C frame's 'fork' fitting. Would be nice if it did though. The e dog bones increase the ride height though. And an e linkage comes with (whisper it) grease nipples. Ohh, nipples.
Guest Posted October 23, 2009 Report Posted October 23, 2009 I swear someone mentioned greased nipples. Who? Wha? Where? Oh... as you were.
kwakbiker Posted October 24, 2009 Report Posted October 24, 2009 E ride height adjuster has a threaded end to mount into the E frame, that won't fit on the C frame's 'fork' fitting. Would be nice if it did though. The e dog bones increase the ride height though. And an e linkage comes with (whisper it) grease nipples. Ohh, nipples. Could of sworn they went in....but as youve said nipples i no longer care
