Cibbersicks Posted October 10, 2009 Report Share Posted October 10, 2009 Bought myself a crash damaged 675 at the right price this week, Looking closer, the rear brake caliper carrier has rubbed against the rear disc, and it looks like its been doing so for some time., It's done 15k so It will have had a few rear tyres so I'm wondering if it's something to do with the spacers? Or is this a common problem? Does anyone know the what the dimensions for the spacers should be? Just so I can compare them to the ones in this one.... Link to comment Share on other sites More sharing options...
Cibbersicks Posted October 11, 2009 Author Report Share Posted October 11, 2009 Anyone? No? Dussst? BUMP Link to comment Share on other sites More sharing options...
Cibbersicks Posted October 11, 2009 Author Report Share Posted October 11, 2009 Double post... Link to comment Share on other sites More sharing options...
will#224 Posted October 11, 2009 Report Share Posted October 11, 2009 Not seen that before, my sisters fella has ran one for a few years as a manx bike and even after a few crashes never seen it. Maybe they have over torqued the spindle squishing the spacer and allowing the carrier a bit too close? Link to comment Share on other sites More sharing options...
tootall Posted October 11, 2009 Report Share Posted October 11, 2009 Spacers in the wrong sides? How does it look from the back? Wheel central or not? Chain run straight? Maybe a bent caliper carrier from a previous off? Link to comment Share on other sites More sharing options...
TriumphBen Posted October 15, 2009 Report Share Posted October 15, 2009 Never seen that one mate, all I can suggest is incorrect spacer or damaged carrier in a prev off! let us know what you find mate!! Link to comment Share on other sites More sharing options...
Cibbersicks Posted October 15, 2009 Author Report Share Posted October 15, 2009 I've got the dimensions for the spacers back from Fowlers today, I will check them when I get home. The carrier looks perfect apart from the arear where it's touched the disc.... hmmm the plot thickens.. Link to comment Share on other sites More sharing options...
lorenzo Posted October 15, 2009 Report Share Posted October 15, 2009 Is the disc it's rubbing against a sort of spiked pattern, and the sprocket looks very worn out? If so, the wheel's on the wrong way. Link to comment Share on other sites More sharing options...
tootall Posted October 15, 2009 Report Share Posted October 15, 2009 Is the disc it's rubbing against a sort of spiked pattern, and the sprocket looks very worn out? If so, the wheel's on the wrong way. Took me a minute but then pmsl Link to comment Share on other sites More sharing options...
Cibbersicks Posted October 15, 2009 Author Report Share Posted October 15, 2009 Is the disc it's rubbing against a sort of spiked pattern, and the sprocket looks very worn out? If so, the wheel's on the wrong way. Laurence, have you ever considered becoming a comedian....? *...scuttles off to garage mumbling, to check if Loz is right.....* Link to comment Share on other sites More sharing options...
buster Posted October 15, 2009 Report Share Posted October 15, 2009 Is the disc it's rubbing against a sort of spiked pattern, and the sprocket looks very worn out? If so, the wheel's on the wrong way. Class, glad I wasn't mid drink at the time Link to comment Share on other sites More sharing options...
