lorenzo Posted September 29, 2009 Report Share Posted September 29, 2009 OK, huge wealth of collective knowledge, what seats will fit on a GS1000, off about a 1980 model? There's very little on ebay for the thou, but there's one which looks tidy enough off a 750, and one off a 550 too. Othwrwise I'm going to have to go to ebay US and get this little beauty: Link to comment Share on other sites More sharing options...
tootall Posted September 29, 2009 Report Share Posted September 29, 2009 Hahahaha do it! You could do one of those mental japanese gang bikes. Cant fuckin remember what they're called though, buko? sako? bukkake? Nonononono not that. Link to comment Share on other sites More sharing options...
lorenzo Posted September 29, 2009 Author Report Share Posted September 29, 2009 That's it, I'm joing a sudoku kareoke gang... Link to comment Share on other sites More sharing options...
lorenzo Posted September 29, 2009 Author Report Share Posted September 29, 2009 Got it: Bosuzuko, them's the fellers. I use a shower cap as a helmet and wear curly turkish slippers, I'll fit right in. Link to comment Share on other sites More sharing options...
deviant Posted September 30, 2009 Report Share Posted September 30, 2009 Loz. I've got a seat off a '79 GS400. Don't know if they had anything in common with the bigger bikes, but if you want I can take some photos/measure up/etc. If you reckon it would fit it's yours. Link to comment Share on other sites More sharing options...
dodgy_tom Posted September 30, 2009 Report Share Posted September 30, 2009 That seat is awesome. You wish you had the man grapes to use it. Link to comment Share on other sites More sharing options...
lorenzo Posted September 30, 2009 Author Report Share Posted September 30, 2009 Loz. I've got a seat off a '79 GS400. Don't know if they had anything in common with the bigger bikes, but if you want I can take some photos/measure up/etc. If you reckon it would fit it's yours. Yup, measure away. I've no idea either, but it's worth a go, isn't it. I'll get my tape measure out too, but there's a worrying lack of bracketry on the top of the frame: I suspect that there's supposed to be clip type bits that are on bolt on plates etc, but there's just mainly plain tubing. Hopefully, once there's a tank on there I can get a better idea of where it should sit etc, but if I'm going to have to make up fasteners etc for the frame (I'd rather not, and there may be some in one of the boxes of bits) then somethign that's designed to go on is always going to be better than botching one on. Anyway, yes please, see what size it is, thanks. Link to comment Share on other sites More sharing options...
FlatTel Posted September 30, 2009 Report Share Posted September 30, 2009 Got a manual Loz? http://www.repairmanualclub.com/motomanual...ex.php?dlid=517 the site needs registration , but its a safe - hassle free type Just downloaded it and no helpful pics of the seat mounting though! Link to comment Share on other sites More sharing options...
FlatTel Posted September 30, 2009 Report Share Posted September 30, 2009 Your frame looks like it has all the lugs its meant to, the seat has an under-pan that fixes it it appears.... the url for all the bits is here suzuki gs1000 fiches hope that helps!! (I find the online part-fiches a godsend when trying to put a box-of-bits together again) Link to comment Share on other sites More sharing options...
lorenzo Posted September 30, 2009 Author Report Share Posted September 30, 2009 You're a star Tel. I suspect that most of the bits that attach onto the bottom of the seat are so you can strip it for recovering perhaps? Deviant, does your seat look like it's got these bits on it? If so, then it should just be a matter of making sure it fits between the tank and the tail plastics. Link to comment Share on other sites More sharing options...
FlatTel Posted September 30, 2009 Report Share Posted September 30, 2009 heres the part breakdown from that fiche mate. 1 45100-49002-40P SEAT (STEP TYPE) 2 46211-49000.HANDLE, PILLION RIDER 3 46212-49000.CUSHION 4 01107-08208.BOLT 5 08322-11088.WASHER 6 08321-21088.LOCK WASHER 7 46213-49000.END, HANDLE 8 45191-49001-05L PLATE, SEAT LOWER 8 45191-49001-03F PLATE, SEAT LOWER 9 09148-05012 NUT 10 09200-06018 PIN 11 04111-20158 COTTER PIN 12 09321-08006 CUSHION 13 09321-10001 CUSHION 14 45213-47000 STRIKER, SEAT LOCK 15 08310-11068 NUT 16 08321-21068 LOCK WASHER 17 08322-21068 WASHER 18 09160-06027 WASHER (6.5x20x1.2) 19 45500-49870-05L COVER, SEAT TAIL 20 68160-49060-72B. TAPE SET 21 45500-49002-03F COVER, SEAT TAIL 22 68160-49060-72D. TAPE SET 23 45522-49000 MOULDING, SEAT TAIL COVER 24 45523-49000 CLIP 25 09169-06016 WASHER 26 08319-21068 NUT 27 95700-45813 SEAT LOCK SET 28 02112-05128 SCREW 29 08321-21058 LOCK WASHER 30 95722-45000 SPRING, HOLEMET HOLDER 31 02112-05088 SCREW Link to comment Share on other sites More sharing options...
lorenzo Posted September 30, 2009 Author Report Share Posted September 30, 2009 Guh. Well, looking through the fiches of all the differen gs models for that year, not 1 is the same. Only the 1000's have the seperate plate underneath too, so it looks like I'm kinda limited to gs1000 bits. Nice link though Tel, I'll keep ploughing through it tomorrow when my eyes are working a bit better, see if any later models have something similar. Link to comment Share on other sites More sharing options...
deviant Posted October 1, 2009 Report Share Posted October 1, 2009 yeh, 400 one looks nothing like that - it is hinged on one side on a couple of pins, with the seat lock on the other, so it flips up to (IIRC) the right. Link to comment Share on other sites More sharing options...
