f1 light on gsxr600 k1
nedster
the oil light came on then the f1 light started flashing any help
the bikes got 7400mls on it and it runs fine
:icon_salut:
Checkout the servo and cables for the exhaust butterfly valve as its a common problem on gixxers-from(my very poor)memory i think if you can trace the diagnostic block connector and join two wires-white/red &black/white it'll give the code for what it thinks the problem is--try googling that info and it'll probs be more helpful mate
Open your rear seat and you'll see a black cap covering a connector/harness on the left side of the seat. If you take the cap off, you'll see it appears to be a normal harness. With your key in the ignition and bike turned to "on" (but not running), take a paperclip and short the two connectors out (by touching the two contacts together) It should display a code on the dash.
GSXR Fuel Injection (FI) Code List:
C14 - THROTTLE POSITION SENSOR
C15 - ENGINE COOLANT TEMPERATURE SENSOR
C21 - INTAKE AIR TEMPERATURE SENSOR
C22 - ATMOSPHERIC PRESSURE SENSOR
C23 - TIPOVER SENSOR
C24 - IGNITION SIGNAL #1
C25 - IGNITION SIGNAL #2
C26 - IGNITION SIGNAL #3
C27 - IGNITION SIGNAL #4
C28 - SECONDARY THROTTLE VALVE ACTUATOR
C29 - SECONDARY THROTTLE POSITION SENSOR
C30 - SECONDARY THROTTLE CONTROL UNIT
C31 - GEAR POSITION SENSOR
C32 - INJECTOR SIGNAL #1
C33 - INJECTOR SIGNAL #2
C34 - INJECTOR SIGNAL #3
C35 - INJECTOR SIGNAL #4
C41 - FUEL PUMP CONTROL SYSTEM
C42 - IGNITION SWITCH SIGNAL
C46 - EXHAUST CONTROL VALVE ACTUATOR (1000 ONLY)
