MarkyRR Posted September 13, 2009 Report Share Posted September 13, 2009 Hi folks, wonder if you brainy lot could help me with a bit of advice please? I've got a 1998 R1 as a track bike. I know it's a 4xv model, and I'm looking at a second pair of wheels for it to run a set of wets. Thing is, the pair I'm looking at is advertised as being from a year 2000 model, but still a 4xv. Am I right in thinking these would fit fine, and that there wasn't really any difference in the R1's until 2001 onwards? Just a little unsure as to what the 4xv, etc actually means - I thought the number changed each year....obviously not though..... Thank you *edited for spelling mistakes Link to comment Share on other sites More sharing options...
fastfreddybikes Posted September 13, 2009 Report Share Posted September 13, 2009 Hi folks, wonder if you brainy lot could help me with a bit of advice please? I've got a 1998 R1 as a track bike. I know it's a 4xv model, and I'm looking at a second pair of wheels for it to run a set of wets. Thing is, the pair I'm looking at is advertised as being from a year 2000 model, but still a 4xv. Am I right in thinking these would fit fine, and that there wasn't really any difference in the R1's until 2001 onwards? Just a little unsure as to what the 4xv, etc actually means - I thought the number changed each year....obviously not though..... Thank you *edited for spelling mistakes I bought a set of wheels for my 2000 model which was 5jj designation but wheels were still stamped up for 4xv and fitted fine so it will be same other way round. The only problem i had was when i changed the wheel bearings turns out they are a bit of a nightmare on the front as some differents sizes were used on 2000/2001 model r1s so you may find your front spindle may not fit the bearing fitted to the 2000 wheels but for a few quid you can easily change bearings to a different internal diameter to fit your spindle/wheel specs. Link to comment Share on other sites More sharing options...
foo Posted September 13, 2009 Report Share Posted September 13, 2009 Am I right in thinking these would fit fine, and that there wasn't really any difference in the R1's until 2001 onwards? Just a little unsure as to what the 4xv, etc actually means - I thought the number changed each year....obviously not though..... Thank you The 4xv is the model designation. 4xv ran from 1998 to 1999. The 2000 - 2001 bike was a 5jj, and 2002 - 2003 5pw (IIRC). The 4xv and 5jj are very similar. Any wheels from a 4xv will be identical to yours, and the 5jj ones almost certainly will also fit. I'm not sure about 5pw ones though. Link to comment Share on other sites More sharing options...
MonkeyJim Posted September 14, 2009 Report Share Posted September 14, 2009 The 4xv is the model designation. 4xv ran from 1998 to 1999. The 2000 - 2001 bike was a 5jj, and 2002 - 2003 5pw (IIRC). The 4xv and 5jj are very similar. Any wheels from a 4xv will be identical to yours, and the 5jj ones almost certainly will also fit. I'm not sure about 5pw ones though. The Foo-ster is correct. Most but not all parts are interchangeable between the 4xv and 5jj models. The wheels are a direct swap, so you should be fine there. Also the front wheel, discs etc from the early R6's is also a direct swap, but the rear wheel is not. Link to comment Share on other sites More sharing options...
MarkyRR Posted September 14, 2009 Author Report Share Posted September 14, 2009 Thanks very much for the help guys, brilliant! A set of wets here we come then! Never ridden on them, so that should be an experience Link to comment Share on other sites More sharing options...
trackdaybob Posted September 14, 2009 Report Share Posted September 14, 2009 Also a 5pw front wheel will fit 4xv & 5jj's but not the rear. Link to comment Share on other sites More sharing options...
