Help - spacer required
CRM
I hope someone here can help me. @DesmoEddy i am wondering if you can based on previous epic work done for me
I need an oval 2mm thick alloy spacer making if possible please
Based on the old fuel pump gasket, the new one from a SRAD is identical with the exception of a deeper rubber seal on one side.
I need a spacer to sit outside the seal area to allow a crush zone so to speak meaning i can tighten the new gasket and spacer between the flat surface of the tank and fuel pump.
Hope that makes sense.
I would commission a few of these if possible too.
Old one is covered in red shite, new one is not.
So i want to thicken the new gasket metal area by around 2mm (will measure accurately later)
Edited by CRM
17 hours ago, Ray Von said:
Bet their same as the TL's too.
i bought one for a TLR - its too big. same layout but larger. the SRAD one and one ending 20 or 21 for the TLS fits
Guest
Reply to this topic...
  Only 75 emoji are allowed.
