HOGG Posted March 26, 2020 Report Posted March 26, 2020 Is there a motorcycle webpage with "what wheels fit which bike?" Or if not, does anybody know if zx6r G model wheels would fit a zx6r F model Cheers guys Quote
Jenny Pryde Posted March 26, 2020 Report Posted March 26, 2020 (edited) 1 hour ago, HOGG said: Is there a motorcycle webpage with "what wheels fit which bike?" Or if not, does anybody know if zx6r G model wheels would fit a zx6r F model Cheers guys If you want to play the Mix & Match game, you will be much better off selling your Kawasaki and buying a Suzuki. Or pose this question on a bike-specific forum. Edited March 26, 2020 by Jenny Pryde 1 Quote
HOGG Posted March 26, 2020 Author Report Posted March 26, 2020 Just wanted to know if G wheels would fit the F model... Quote
Jenny Pryde Posted March 26, 2020 Report Posted March 26, 2020 Try here https://www.zx6r.com/forums/mechanical-and-technical.38/ Quote
Damnthistinleg Posted March 26, 2020 Report Posted March 26, 2020 I believe there is a good degree of swappability in the Kwaks of that era but I couldn't give an accurate guide as to what will fit what. Quote
TLRS Posted March 26, 2020 Report Posted March 26, 2020 There is a site somewhere with a list with some data. No idea what it’s called. Some measurements can be taken from a bike without any disassembly. Front disc spacing, if you’re going with the discs too.. and chain alignment. It can be a royal pita to get it all bob on. Especially on fancy wheels, as there isn’t much to play with (machine). Quote
HOGG Posted March 26, 2020 Author Report Posted March 26, 2020 2 hours ago, Jenny Pryde said: Try here https://www.zx6r.com/forums/mechanical-and-technical.38/ It's okay, I'll just get mine powder coated (after covid 19 obviously) Quote
ZXRRDave Posted March 26, 2020 Report Posted March 26, 2020 The G model wheel uses a 25mm spindle and has no speedo drive, the F uses 20mm spindle and has a speedo drive. You could make it fit easy enough, but you're better off just using an F wheel. 1 1 Quote
