350Lc Carb Air Screw Stuck
Fatbloke
Poorly plated steel screw into an aluminium carb body, stand for a while and the two metals can react and pretty much weld themselves together. I assume that the head of the screw is chewed? You could try a really small easy out and drill down the centre with a steady hand, the easy out may grip and pull whats left of the screw to bits getting it out of the way, other than that its drill the thing out and hope you don't damage the thread in the carb body.
If the air screw is set correctly you could just leave it in place though?
