r1-daz Posted March 12, 2012 Report Share Posted March 12, 2012 Does anybody know what's involved in converting a dt125mx into a 175? I havn't checked on the stroke yet but does the con-rod need changing? Is it a straight conversion? Any help or advice would be appreciated. Link to comment Share on other sites More sharing options...
wavydavy Posted March 12, 2012 Report Share Posted March 12, 2012 A quick google says they share the same stroke (56.0 x 50 vs 66.0 x 50), which sounds helpful... Link to comment Share on other sites More sharing options...
wazrs257 Posted March 12, 2012 Report Share Posted March 12, 2012 I would say it's just a straight forward top end swap, as the stroke is the same for both. Not sure what size carb the 125 uses, but the 175 has a 28mm Mikuni, easy enough to get hold of (As fitted to air-cooled RDs). If you wanted to complicate the issue by running an oil pump, you may need the 175 one though. Then just gear it to suit Link to comment Share on other sites More sharing options...
2Smoke Posted March 16, 2012 Report Share Posted March 16, 2012 Top end change mate, think the 175 runs a slightly larger main jet so best check on that one. Not run autolube on mine so cannot comment on the pump output sorry. Link to comment Share on other sites More sharing options...
r1-daz Posted March 19, 2012 Author Report Share Posted March 19, 2012 Thanks for the advice Link to comment Share on other sites More sharing options...
rossm Posted March 19, 2012 Report Share Posted March 19, 2012 I have a feeling the 125 was a 4 stud mounting setup and the 175 was 6, but it's been 20~ish years since I stripped one down so could be talking complete bollox Link to comment Share on other sites More sharing options...
2Smoke Posted March 19, 2012 Report Share Posted March 19, 2012 I have a feeling the 125 was a 4 stud mounting setup and the 175 was 6, but it's been 20~ish years since I stripped one down so could be talking complete bollox Not on the MX series, the cylinder is a 4 stud & the head is a 6.. Link to comment Share on other sites More sharing options...
