Kayla Posted November 26, 2011 Report Share Posted November 26, 2011 Do any of you have a mid to late 90s, or early 00s YZ250? If so, would you mind awfully waving a tape measure in the vague direction of the rear engine/swingarm mounting point please? I'd like to know how wide the engine is across the mount, inside the swingarm Link to comment Share on other sites More sharing options...
nzknut Posted November 27, 2011 Report Share Posted November 27, 2011 What're you planning Kayla? I'm putting a CR250 engine with a 55horse go-kart tune in a KR1S next year Link to comment Share on other sites More sharing options...
Kayla Posted November 27, 2011 Author Report Share Posted November 27, 2011 What're you planning Kayla? I'm putting a CR250 engine with a 55horse go-kart tune in a KR1S next year I'm looking at replacing the SZR660 engine with a YZ250 one Link to comment Share on other sites More sharing options...
CRMotard Posted November 27, 2011 Report Share Posted November 27, 2011 I think the width at the rear of the motor will be the least of your troubles your going to most likely have to make a sleeve and spacers (or top-hat bushes) as the yz250 will most likely be skinnier than the 600. or if its wider, you could always take a little bit of meat of the cases... check to make sure you can get away with it first before trying it. if your actually thinking about doing the project, why not grab a cheap set of cases first to make sure its doable... much more reliable to take measurements yourself than relying on other people to remember for you. then you can make your engine mounts while you hunt around for a really nice/cheap 250 motor http://www.ebay.co.uk/itm/YAMAHA-YZ250-YZ-250WR-1990-90-LEFT-RIGHT-CRANK-CENTER-CASES-/230705338849?pt=Motorcycles_Parts_Accessories&hash=item35b71c19e1#ht_2536wt_1185 http://www.ebay.co.uk/itm/96-01-Yamaha-YZ250-BOTTOM-END-ENGINE-CRANKS-CASES-250-2-Stroke-MOTOR-TRANY-/150700109709?pt=Motorcycles_Parts_Accessories&hash=item23166d2f8d#ht_3074wt_952 but yeah... the rear mount will be the least nightmarish part of the build... enjoy Link to comment Share on other sites More sharing options...
Kayla Posted November 27, 2011 Author Report Share Posted November 27, 2011 then you can make your engine mounts while you hunt around for a really nice/cheap 250 motor but yeah... the rear mount will be the least nightmarish part of the build... enjoy Thanks It'd be easier/cheaper for me to buy a complete bike to measure up than buy an engine plus all of the other stuff that's needed to make it make a noise, it's just finding a decent-ish non-f-ed mx bike that isn't being touted as 'mint with the bands, hew' is pretty difficult... Then if it's a no-go I can just sell the bike on. Link to comment Share on other sites More sharing options...
mattyzx6r Posted November 28, 2011 Report Share Posted November 28, 2011 I think IforB has a Yz? might be worth a pm. Link to comment Share on other sites More sharing options...
CRMotard Posted November 28, 2011 Report Share Posted November 28, 2011 just buy a bargain basket case and rebuild from the ground up... new bearings for whole motor 70 pounds crank rebuild with new rod 150 pounds new piston 70 pounds gaskets and seals 50 pounds labour to get the cases split and represses (if you dont have a press) -try to get one that has a half decent cylinder lining even if means asking before you buy, put down a deposit and say "well youve told me the cylinder coating is good so Ill take the head off and check, if its fine like you've said it is then consider it sold" Link to comment Share on other sites More sharing options...
