speedy sie Posted October 15, 2011 Report Share Posted October 15, 2011 here are my xro9cr-01/2 cam timings and some other useful spec.this is if it still in the same spec as mr suzuki man left it... head thickness.114.65mm... xro9cr-04/2 cylinder thickness 72.85mm. xr09cr-01/3 crank shaft............................xro9cr-01/3 base gasket 0.25mm head gasket 0.5mm cams in..x106r130xr0810 ,but now has an xro9-01 cam fitted. ex..yer2r170xro8 (1),but now has an xro8-10 cam fitted. i think they are the same spec?? engine caseing are date 2000,so are most of the parts aswell. open...@1mm lift..in..19 btdc... ex 41 bbdc degree closed @1mm lift..in..46 abdc....ex 19 atdc degree max lift..(l.c).........in 104mm......ex 102 degree valve to piston.... in 0.8mm.......ex 1.2mm average squish = 0.648 oil clearence crank shells 0.045 / on rod shells 0.058 carb rubbers.xro6o jc040n1 these are the short rubbers,xro62 jc040n2 longer,the different lengths are to alter the inlet length and thus alter the rev pick up. __________________ ummmm...xro parts..better get some bog roll....to clean um of up... Link to comment Share on other sites More sharing options...
