addiction269 Posted November 9, 2008 Report Posted November 9, 2008 also i have just paid to have my swingarm bearings removed and will need to pay again to get them fitted - what bit of kit is required to do this yourself?
spacemonkey Posted November 9, 2008 Report Posted November 9, 2008 also i have just paid to have my swingarm bearings removed and will need to pay again to get them fitted - what bit of kit is required to do this yourself? A drawbar and tubes of the right ID and OD would be the simplest way. You'd probably want a lathe to make the tubes on unless you can happen to find some just the right size... I hydraulic press is nice if you have one....
addiction269 Posted November 9, 2008 Author Report Posted November 9, 2008 ive been looking at hydraulic presses - quite big but not too expensive. but not sure where youd start with that!
spacemonkey Posted November 9, 2008 Report Posted November 9, 2008 ive been looking at hydraulic presses - quite big but not too expensive. but not sure where youd start with that! Just the same as the drawbar method but with a hydraulic ram instead of a threaded bar and nuts......... You need to support one part, push the other. Hey presto and they come apart!
