stem bearing removal
addiction269
Posted
im having trouble removing the stem bearing of the bottom yoke, ive tried heat and a chisel as it says but it doesnt want to move is there a specific tool or do i need to cut it off?
Posted
Angle grinder. It's the only alternative to hours and hours of fucking about with a succesion of pointy chisel type tools and lots of swearing. A hack saw won't touch it either, ask me how I know...
Posted
For what it's worth, I've had success with a very long, two leg puller.
Posted
ive been looking at bearing pullers but there not very long!
Posted
Angle grinder with a cutting disc in, I favour 1mm but a 3mm will do, no need to go mad with it though, donn't cut all the way through it, just weaken it sufficiently so that one swift smack with a chisel and the inner track will crack and voila ! It should just tap off :unsure:
Posted
I got this one from Cromwell Industrial. It's really long! If you can't find it, make it!
An angle grinder will work but it is very, very easy to damage the stem!
Posted
weld around the the inside of it,it will shrink and fall out..........easy
Posted
Hang on...... Surely the inner race would be on the outside of the stem, not on the inside...... How can it drop out?
Posted
things expand when heated. not shrink
Posted
Ah, sorry, got it. Sounds like a great way to do it! It was the dropping out bit that confused me. I thought that the inner race can't drop out 'cos it is not inside the stem, it is outside it.
Posted
I agree about the heat side of things, I think that's half of what undo's it when I've gone through them in the past with a grinder, they get sizzling hot and that in turn means you can make a good bit of movement on them. Don't dispair though mate, they're a bitch to do sometimes, but once they get going, they seem to come off OK, it's just a matter of getting them started.
Posted
If its an alloy yoke, just press the stem out of the bottom. Thats the normal way to do it.
Posted
I think he means the outer race still in the frame. Running a small bead of weld on them makes them contract. Works a treat. Did it last week on a gearbox bearing on some old clunker of a Brit bike. The bloke had tried everything to get it out without damaging the cases, couple of runs of weld, tap with a punch and out she came.
Posted
yip sorry,too much typing,not enough reading !!but yeah to get the cup(outer race ) outa the frame you can weld it and it will shrink etc
Posted
no not the race in the frame just the bearing on the stem the race in the frame is easy i can buy a tool for 30 quid that'll knock that straight out - or a bar lol- don't have a press keep looking at them any info on thatd be great also dont have a welder as yet need one!!! cutting is sounding best so far ...
Posted
I know that's what you meant. I was just on about what he meant. :pb2::D
That's what I meant. :pb2:
Posted
im glad everyone means what they meant to mean otherwise that'd mean someone hadn't meant it.....maybe
Posted
Glad you get it, coz I'm confused as hell.
