ZXR750R K1 Single Seat?
STORMO
Posted
hey everyone any info much appreciated, bought a 91 ZXR 750R K1 last month and not sure if the single seat on it is a copy replacement to go on the J model, as its made from fibreglass and the last 2 bolts that hold it to the tank are out of line and dont match up. i can find a copy single seat unit on e bay but it just says 91-93 model, but im not sure if i need a specific fit for the aluminium sub-framed k1 model.....Please help :rolleyes:
Posted
fwiw the single seat units on the zxr400-sp were fibreglass not plastic, and use fasteners rather than lugs to attach to the tank, so it could well be an OE seat.
Posted
thanks but theres no lugs on this one just holes for fasteners, and there about 10mm too low to match the threads on the tank which is different to a standard zxr 750 of same year so it could be off the 400. Anyone seen what a zxr750rr single seat is made of though????
Posted
I'm sure they were fiberglass as being one piece it would have been much too expensive to injection mould, the m was 3 piece.
It's been a good fifteen years since I had mine but the K seat unit had a hole on either side at the front that had grommets and a screw that went into threads on the ali tank so was not compatible with the road going steel tank.
Not sure if any of that helps.
Posted
Just had a butchers at the seat unit on my K1 and it's one piece injection moulded.
Looks expensive.
Beginning to wonder if I should have track day'd it so much this year !
Posted
Kawasaki want nearly £1400+VAT for the seat unit, my K1 will be sticking with it's fibreglass unit.
Posted
Looks expensive.
thanks mate,
oh well looks like someone`s changed mine to fibreglass at some point, stil baffeled why the holes with gromits at the front dont line up?? oh and there aint no new £1400 moulded ones left at kawasaki uk, so dont go throwing yours down the track!!! :pb2:
Posted
hey dude if ur`s is fibreglass does it fit perfectly??? and do u know the make or where to get one? cheers mate
Posted
Yes, I only noticed it wasn't original when I took it off and looked on the inside. At push the opening that holds the seatpad isn't as sharp as an original but you can't tell with the seatpad fitted. It's not marked up who made it but found this on ebay which might be of interest.
http://cgi.ebay.co.uk/RACE-REAR-SEAT-TRACK...id=p3286.c0.m14
Bit of a shame these guys don't do seat units/sidepanels, included for reference.
http://cgi.ebay.co.uk/Kawasaki-ZXR750-ZXR-...id=p3286.c0.m14
Good luck with the hunt mate
Posted
Cheers mate, think i`ll order a new one from the first link and go from there....Watch this space!!
