Titanium Testing
Richy
Posted
Is there an easy test to find out if something is titanium? It looks like stainless steel, sounds like stainless when you tap it but seems to light to be stainless , any ideas?
Posted
You can weigh it, check the volume by seeing how much water it displaces and then calculate the density to see if it matches a titanium alloy. (You don't want your parts to be made of pure ti.)
I think it was archimedes or some Greek chap who came up with the idea for checking if gold was genuine or not.....
Posted
I think it was archimedes or some Geek chap who came up with the idea for checking if gold was genuine or not.....
Posted
FIM use 3% Nitric acid test. No reaction Ti, leaves a black spot if steel. God I'm an anal bastard sometimes :eusa_pray:
Best guess on a source of on Nitric acid is probably QRust from Halfords etc.
For more complex or patina'd parts (used race engine valves etc ) FIM regs revert to displacement/mass calculations.
Posted
The part dosent stick to a big magnet but neather will a good grade stainless, I think i have some of that rust eater stuff some were, but if its STAINLESS steel it wont stain that as well as Ti. :D
Posted
The part dosent stick to a big magnet but neather will a good grade stainless, I think i have some of that rust eater stuff some were, but if its STAINLESS steel it wont stain that as well as Ti. :rolleyes:
Should stain the Iron in the Steel regardless.
Posted
Ti weighs about the same as Al so it should be obvious if it is S/steel
